6.2L V8 Discuss the 6.2L V8
Dealer Problems
Old 12-10-2011, 12:19 PM
stuffdeer's Avatar
stuffdeer
stuffdeer is offline
Now my 4x4 is only intermittintly locking in when hubs are in auto...
Heading to a dealer closer to home Monday at 8.
Old 12-10-2011, 06:23 PM
stuffdeer's Avatar
stuffdeer
Just come out to the truck...now my radiator is leaking.
Old 12-22-2011, 10:06 AM
jmiley's Avatar
jmiley
jmiley is offline
Originally Posted by stuffdeer
At this current time...my truck has 27k on it. It is a 11' F250 4x4 Extra Cab Fx4.
Its been to the shop at 4k because a transmission seal blew and was pouring out transfer fluid.
Now its in for the rear axle not locking (even though the screen says it is).
Steering making a pretty loud noise when turning
Shocks being shot
and being unsafe on the highway, pulling horribly, hitting a bump and its hard to keep in a lane.
Dropped it off at 8 am yesterday. I got a call at 3 yesterday, saying the rear axle was fine.
Was told steering was fine and it was my oversized tires rubbing causing the noise. I laughed and said, oh no. She laughed and said oh yes and could show me where they were rubbing.
I laughed and started yelling, I told you it was doing it when in PARK.
She also told me the shocks were perfectly fine.
So they say they will look at it again.
Call me a half hour later and ask me for my wheel lock...
What haven't even pulled anything off to look at it???
They said one lower ball joint was loose.
Haven't heard anything since the wheel lock call.
I don't want to state the name of the dealer yet, but will be if this isn't taken care of. They are a huge dealer in Southeastern MI
Rant over, sorry...
Hate to say it but when you start altering a vehicle by putting larger tires on it, you put additional stress on steering as well as other systems on the truck, and the body sometimes does not have proper clearance.
Don't get me wrong it is your truck and you can do whatever you want but when you start altering the truck and you have problems that may be caused by these alterations you can't expect the dealer to take care of them.
Yelling at the dealer is typically not a good idea as that is going to make them less eager to help you.
Good luck with your truck.
Old 12-22-2011, 11:24 AM
Super08's Avatar
Super08
Super08 is offline
With the 35's you may have to go to a HD stabilizer or go to a dual stabilizer. Especially if you have any type of a lift done. Speaking of which if it is lifted at all the caster will need to be corrected as it will also make the steering oscillation problem much worse.
QwkTrip
2009 - 2014 F150
17
03-03-2014 07:39 PM
rugbybobert
2009 - 2014 F150
20
02-22-2014 09:44 PM
gbiker
6.7L Power Stroke Diesel
18
10-15-2013 10:58 AM
ReForder
2004 - 2008 F150
09-20-2005 01:13 PM
THE04F250
11-21-2004 07:32 AM
Quick Reply: Dealer Problems
