1999 F-350 Cold No Start
Old 11-29-2011, 03:07 AM
Aquaticedge's Avatar
Aquaticedge
Aquaticedge is offline
Thats an even simpler test. any ideas on the code thrown before and what it could point to?
Old 11-29-2011, 03:09 AM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
It points to an electronic feedback signal error, I wouldn't worry about it, I've seen it a couple of times, from disconnecting batteries. Just clear it and see if it comes back. If not I think it's fine.
Old 11-29-2011, 03:11 AM
Aquaticedge
Makes sense. I'll Pass along the Relay suggestion, Post back if there's any change in the patient at all
Old 11-29-2011, 03:12 AM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
https://www.ford-trucks.com/forums/5...-no-start.html
There is a more in depth discussion on that code from last month
Old 11-30-2011, 04:03 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 12-02-2011, 03:14 AM
Aquaticedge
Sorry, there's been no progress with this... too busy working on getting trains ready for Christmas Runs to play with this truck. We'll get back to it!
Old 12-02-2011, 03:40 AM
BigAlsPSD's Avatar
BigAlsPSD
Keep at it, we are here to help and learn too. Good luck.
Old 12-05-2011, 05:52 PM
Aquaticedge
have a tiny bit of free time. What is the Exact location of the computer on this Truck. It's the right side but where? and under what?
Old 12-05-2011, 05:55 PM
BigAlsPSD's Avatar
BigAlsPSD
Located on the firewall, unbolt the center bolt under the master cyclinder/fuse box area to unplug then 2 bolts inside.
Here this will help, it is for adding a chip but will help with location and pictures.
https://dp-tuner.com/skin/frontend/d...stallation.pdf
Old 12-05-2011, 05:57 PM
Aquaticedge
is the ICM in the same area?
Old 12-05-2011, 06:01 PM
BigAlsPSD's Avatar
BigAlsPSD
The IDM?(Injector Drive Module) is located inside the driver's side inner fender. You need to remove the inner fender then it is located, essentially behind the F-X50 badges, on the fender, between the wheel well and the driver's side door. Here is a pic for reference, you do NOT have to remove the fender, this is for location purposes only.
Name:  IDM without fender.jpg
Old 12-05-2011, 06:02 PM
Aquaticedge
They dont make these things easy do they...... *sigh*
  #28
Old 12-05-2011, 06:03 PM
BigAlsPSD's Avatar
BigAlsPSD
I edited the above post and added an image for reference.
  #29
Old 12-05-2011, 06:05 PM
Aquaticedge
Thanks for the pics! Glow plugs and controller/module checked out btw. Tested this morning.
  #30
Old 03-10-2012, 01:44 AM
Aquaticedge
I should conclude this thread, Upon checking the glow system etc we narrowed it down to the Injection computer in the fender, replaced it and the CPS and has been fine since
Quick Reply: 1999 F-350 Cold No Start
