1973 F350 CREWCAB desert/dunes budget build by DirtyDeedsIndustries
#76
#77
Lemme know if you need anymore pics. Hope that helps. I'll be taking these off one of these days, they'll get beat to sheit after I get out to the desert. They don't work, plus they'll be in the way of the cage.
Keith
#78
The driver side is definitely lower than the passenger side. It rubbed the fenders a little and started to pull the lip down a little making it rub more and more so I rolled the lip. It rubs a lot less and the tire no longer grabs the fender.
I'll have to wait til middle of week or next weekend to check camber, when I do I'll post up pics.
#79
#80
I also fixed the stiff as a board feature the truck obtained with the loss of the 1100 lb flatbed. The way it was I could jump on the back of the truck and the tire flex was the only suspension flex. The springs would move a bit. It was really hard to drive, hurt my back you know? Here's how it looked before:
Removed U bolts and dropped the rear end one side at a time so the pinion wouldn't twist outta shape and make me have to wrestle it back into shape.
I kept the top two and bottom two leafs if I remember correctly:
Here's how it now looks:
The pics don't do it justice, looks like a low rider with off road tires LOL. When I set up the front end next year it'll have a little more lift, but not much, I wanna keep the center of gravity as low as possible while finding the best compromise of up travel as well. For now here's how it sits now:
Lowered truck about 6 inches, I should've measured before and after. The ride still really sucks with these flat leaves and very little wheel travel, (like 5-7 inches max)
So next weekend I'll try to tie up more loose ends. I'm just glad to fit the truck in the garage now. I have 5 days off over the new years weekend, the truck goes under the knife for some minor surgery (unless I have some customer projects)
Keith
Keith
#81
While I didn't run 35s and I didn't jump it, I could bomb down dirt roads and smoke the cattle guards with the stock suspension and 33s just fine. I would say that just a couple inches of lift with good damping and you would be fine.
On a side note, maybe you should fix the jeep. It looks like it could be on the road faster. What's it need, just a rear end?
#82
ANd a paint job - that one is a little "loud"
#83
#84
dirtydeedsindustries.com kaylie drift - YouTube
DirtyDeedsIndustries.com Kaylie drifting 24V - YouTube
I bought her a new car with the intention of putting a chain driven scooter motor on this one, just have too many projects
#85
I've never set up a beam truck. I had a 93 i beam van with basically Ranger I beams. Just putting a longer shock nearly doubled the travel. Had 14"!!! Now that's not 'clean' travel by any means, i beam travel is already dirty travel, but having different length beams and yada yada, it still mobbed.
I just need to tear into that front end, It's my goal to have it done, extended beams and double swinger steering before April 2012.
LOL Pink and purple wouldn't work on the crewcab? Haha
#86
I put very little miles on the truck and will check u bolt tightness with an impact probably every weekend for the next few weekends just to make sure. I will convert to 4 link sometime down the line so I hate to drop any money on u bolts unless it stops me from driving the truck altogether.
If I run into a really good deal on Leaf springs I'll do it just until I get time to 4 link it, but the deal better be so good when it's time to sell the spring I'll make some money on the deal. Otherwise there is no benefit to changing it. It rides like crap the way it is, but it's sooo much better than it was. Stay tuned, over the next few weekends I'll post up some pretty good pics of actual fabrication, not just of cutting up a perfectly good truck like I have been LOL
#87
#88
Morale of the story: when maximizing wheel travel with leaf springs there is a ton of driveshaft plunge. So if I 4 link this truck I can pull 30" of travel with little to no plunge if I do it right. And if I center the engine that I chose, there WILL be no compound angle to worry about.
Also when linked I can run progressive rate Coilovers which are way more cush for the family. And the list of benefits goes on and on
#90
Thanks for the kind words. Stay tuned, got a 3 day weekend coming up, then 2 days of work and then a 5 day weekend. Truck will be in the garage overnight for the first time since I bought it
