1973 F350 CREWCAB desert/dunes budget build by DirtyDeedsIndustries - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-03-2011, 09:03 PM
77flh 77flh is offline
77flh is starting off with a positive reputation.
Jealous of you west coast guys and those rust free floorboards...
  #32
Old 12-03-2011, 09:19 PM
73f250highboy's Avatar
73f250highboy 73f250highboy is offline
73f250highboy has a good reputation on FTE.73f250highboy has a good reputation on FTE.
looks good... subscribed
  #33
Old 12-03-2011, 11:34 PM
dirtydeeds dirtydeeds is offline
dirtydeeds is starting off with a positive reputation.
Thanks for the kind words guys
I had a very limited amount of time to work on the truck today but got to spend a good couple hours with it. I drove it around town today to get lunch and stop at 4wheel parts direct to inquire about a new rim to replace the really bent one my wife's truck.
After driving around I spent a little time trying to tune this awesome Carter LOL
I know you gotta be smarter than the equipment you're working with so that's why I'm asking you guys for help. Here's the problem:
At low rpm there is a bad hesitation. The harder you punch the throttle the more it does it. Sometimes it'll actually pop out of the carb, and sometimes it'll actuall die. I've adjusted the 2 little screws under the carb. Everytime I turn the screws out it seems to hesitate less. Problem is I've got em as far out as I can get em and the hesitation is WAY better, but is still there a little.
It's got new plugs and wires, cap and rotor, replaced all gaskets on top end and fixed all intake leaks, rebuilt carb including accelerator pump (which squirts out tons of fuel when you punch throttle) and timing is good.
Sorry for the long post.
  #34
Old 12-04-2011, 07:39 AM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Sounds like your accelerator pump either needs a rebuild or needs to be adjusted up one hole for a richer shot. Take the air cleaner off and make sure your getting a healthy squirt of fuel.
  #35
Old 12-04-2011, 08:09 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud of
Subd. kinda curious as to how this goes.
  #36
Old 12-06-2011, 10:37 PM
Quote:
I'll double check, if I remember correctly I've got it set on the hole that squirts the most. I'll confirm this though.
  #37
Old 12-06-2011, 10:38 PM
Haven't worked on the truck since the weekend, but 3 of my wheels came in today, expecting the 4th on Thursday.
My head is still spinning from the above post showing the white wheels painted, right now I'm leaning towards just keeping em white, but who knows.
  #38
Old 12-07-2011, 08:43 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
I personally like the white spokes as well. However, I did paint a set for a tacoma. I used rustoleum Hammered:
Just to keep you thinking about white, here's a set I borrowed for mock up on my old truck:
I am a huge fan of "old school" since it reminds me of when I was a kid and these trucks were new. Don't try to update it too much
  #39
Old 12-07-2011, 09:37 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
I'm a huge fan of white spokes. Here they are on mine:
  #40
Old 12-07-2011, 09:46 AM
Alright! Thx guys for the pics. Anybody else plz keep em comin. The blue trick with white spokes really does it for me. My dads 67 was that same color. I'll track down and post up a pic when I get a chance.
I'm really leanin towards the white now. More nostalgic, and I don't have to do all that prep work
I'm building this into what someone back then would build, only with updated engine and suspension.
  #41
Old 12-07-2011, 09:56 AM
OldStyle's Avatar
OldStyle OldStyle is online now
Rusty Roller
OldStyle has a good reputation on FTE.OldStyle has a good reputation on FTE.
Quote:
Nice! Original paint? Look good!
  #42
Old 12-07-2011, 12:27 PM
ford141's Avatar
ford141 ford141 is offline
ford141 is starting off with a positive reputation.
Not sure if you got your hesitation problem fixed yet, but another thing I'd suggest since you have an FE is to bump your timing up some and see what happens. If I remember right the stock specs are somewhere around 4* at idle, but they really like the idle timing to be up around 12* or so. I usually tune them in by ear by advancing the distributor until the idle speed stops increasing, them back it off until you notice the idle speed dropping slightly. Take a drive and get it hot, then romp on it a few times. If you notice any spark knock back it off a little more. Works good for a stock daily driver type motor if you don't have a timing light available (or the numbers are unreadable on the dampener). You'll be surprised at how much response and driveability this little bit of timing increase adds.
  #43
Old 12-07-2011, 03:01 PM
Quote:
I appreciate that!! I have played with timing a little. I concur with what you're saying, it definitely is sluggish with stock timing compared to when u add more. I've played around just a little, not quite as 'scientific' as u have. Over the weekend I'll follow your steps, and confirm that the acc pump squirts as hard as possible. Thx
  #44
Old 12-08-2011, 08:51 AM
fmc400's Avatar
MSEE
Quote:
Thanks! Original paint, except for the fenders.
  #45
Old 12-10-2011, 03:21 AM
couple pics of the trucks last haul:
Everything that's important in my life right here:
I fired up the plasma cutter and cut the flatbed in key locations to remove it from the frame of the truck. It's strapped down until I go down to the recycling yard tomorrow. They'll weigh the truck before, pull the bed, then weigh it again and gimme my $5 for the scrap, LOL
I'll shoot pics when I'm there with my new phone (hopefully)
Rear body crossmember replacement and bumper build hivoltj 1978 - 1996 Big Bronco 7 02-17-2016 01:28 AM
68 F100 SBFS build; CV, T45, DOHC Saturn5 1967 - 1972 F-100 & Larger F-Series Trucks 24 08-02-2014 11:37 AM
'47 Build Flourmaker 1947 and Older Ford Trucks 65 04-28-2014 01:35 PM
Project "Black Mantis" fosgate forever 1987 - 1996 F150 & Larger F-Series Trucks 48 03-25-2012 01:22 PM
6637 filter on banks sidewinder turbo helifixer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 02-13-2010 12:26 AM
Tags
1973, 1974, 4x4, build, bumpside, cab, crew, crewcab, dirtydeedsindustries, f350, f360, ford, frame, headliner, heat, newer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
