1949 F-1 Radio Mounting Dimensions - Ford Truck Enthusiasts Forums
Old 11-28-2011, 11:54 PM
Moe Craig's Avatar
Moe Craig Moe Craig is online now
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
Well I'm back from my trip and want to start working on installing my radio in my truck... Well I doesn't have the hole radio... but I have just the front section, no tubes... I do not have the cage either... what I need to know is how far from the face of the radio to the mounting brackets suppost to be? Below is a few pic of the Mercury radio I bought from ebay
Old 11-29-2011, 12:32 AM
DRRXR's Avatar
DRRXR DRRXR is offline
DRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputation
Found this floating around out there
Looking up
Bracket drawings
Old 11-29-2011, 01:46 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
The images and the schematic above are thanks to Bob (bobj49f2).
Old 11-29-2011, 10:43 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is online now
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
The way they mounted the radio and it came through the dash are pretty crude but that's how a stock installation looks.
Old 11-29-2011, 11:23 AM
Moe Craig's Avatar
I've saved those drawings myself, but my problem is I do not have the back half of the radio (not even the housing), so I can't measure from the rear. Does anyone know if the cage from a 51/52 truck radio have the same outside dimensions? I have a housing for one of them. Can someone check the mounting from the front where the nose plate is mounted to.
Old 11-29-2011, 11:39 AM
bobj49f2's Avatar
Moe,
I no longer have the radio installed in the truck. Best thing to do is guestimate using the picture posted. I think, but not sure, the case from the later radio should work, or at least made to work.
Look at it this way, a radio in a '48-50 truck is so rare that if you don't get it exactly where it is suppose to be no one will ever be able to tell. Get it close.
Old 11-29-2011, 12:48 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Moe, I am in the other boat right now as I am trying to figure out how to REMOVE my radio!
I just received my shop manual in the mail and it isn't very clear as to what I need to do.
Old 11-29-2011, 03:42 PM
bobj49f2's Avatar
Jeff,
If you have a '48-50 all you should have to remove are the four bolts holding the side flanges to the two braces on either side that's in the dashboard. I don't think there's anything else holding it in. It's been a while since I've removed or installed one of my radios.
Old 11-30-2011, 05:45 PM
Moe Craig's Avatar
Here is a CAD Drawing of a '48-50 Ford Mercury radio
Old 12-07-2011, 04:17 PM
F1Newb F1Newb is offline
F1Newb is starting off with a positive reputation.
I was just going to pm you that I pulled out my radio and was going to see if you wanted to buy it...
They are only 4 bolts behind the speaker grille that holds them in.
I can measure this thing if need be
Old 12-07-2011, 06:38 PM
brain75's Avatar
brain75 brain75 is offline
brain75 is gaining momentum as a positive member of FTE.
dibs, DIBS!
Ok seriously - Moe was first in (here and another thread), and I'd be happy to let him have first shot, but he and I are both looking for the same thing a placeholder for the dash instead of the delete panel or hole.
Send me a PM with asking price, I'd be happy to let you measure, measure myself, or even let Moe receive 1st and then forward on or swap out / give me whichever is the leftover.
Old 12-07-2011, 11:41 PM
Desert Patina'd..haha
Old 12-08-2011, 09:36 AM
Moe Craig's Avatar
Chuck sent you a PM
Old 12-08-2011, 10:26 AM
brain75's Avatar
Moe, I put in the dual 12v electric wiper - I had to remove the support brackets... so for my purpose, it is 100% imagination and fab work to support a radio face. I really don't need the brackets or the back half, etc - just some steel to bite into and run new supports from. After you and Chuck settle up, let me know what you have leftover if you will please.
Old 12-08-2011, 08:26 PM
Moe Craig's Avatar
Quote:
Sure thing
Radio not working??? evanlane5 Ranger & B-Series 1 02-16-2015 02:29 PM
Radio swap question Jake65 1987 - 1996 F150 & Larger F-Series Trucks 14 11-27-2014 09:46 PM
Stock radio installation Zachthemoo2 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-07-2014 11:30 AM
Xm Radio mounting options utah_roper 1999 to 2016 Super Duty 0 02-20-2014 02:11 PM
cb radio install zxsmyers 1997 - 2003 F150 2 07-02-2009 07:22 AM
Tags
1948, 1949, 1952, bracket, bronco, cover, drawing, drawings, f1, f250, ford, innernetworksnet, radio, slip, stereo, truck, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
