POR-15 vs Rustoleum
Hmmmm.....let me see if I understand this....you work in an area where, at one time, they had no compunction about setting off nuclear bombs, and now they're worried about the environmental impact of some paint removal??? Has it ever occurred to the environmental safety team that there might be more impact to the environment if the components fail due to corrosion, and new units have to be built instead??? By the way....there are paint removal techniques that catch the residue.
Sorry....I just had to throw that out there.
Ilya, what we used on the spheres wouldn't be correct for the trailer, necessarily. I'd find your local Tnemec rep and ask for their recommendation. The guys I talked to were very knowledgable (it's their job).
Me too...well mine was $37 quart. I bought one and did the frame and bottom of the cab. had to stretch to get the bottom of the cab done. Then I didn't really like the finish so I bought Duplicolor Bedliner and sprayed over the Chassis Saver. Not sure how long it will last but, touch ups will be done with the Duplicolor. I like the finish it provides.
WOW! Tons of great info from all of you! I think i'll give that Chassis Saver a try. The hardest part for me will be brushing paint on my nice smooth metal. Eeek! But, if it levels out smooth, thats works for me. I appreciate all the info guys! Now with a little luck, I can get my chassis back in the garage, get it warmed up, (freezing temps now), and that thing painted. I'll get pics on here soon....
I just checked out that Chassis Saver. That does look like a real good alternative. Now, if only I hadn't already sparayed the entire chassis (one coat) and the front axle and springs (3 coats) with Rustoleum gloss black. I assume I can probably do a light sand on that however and re-coat it. I will check into that UV protection on the Chassis Saver as well.
i can't tell you that there won't be brush strokes visible. Mine did not flow out like a spraygun application. thats why I sprayed mine with the duplicolor bedliner. then it looked great! kind of a very fine sand finish as best as i can describe. good luck! and DONT get it on anything that you dont want it on.
I got some on my left boot, that was this summer and it looks untouched!
I used my quart over a period of three evenings. I got the lid on the can, put it in 2 large ziplock bags sealed with as much air out as i could get out. I cleaned the brush with lacquer thinner, but it was stiff as a board the next day. so I just bought more brushes. doc said he used foam, I used decent oil brushes hoping for a GOOD finish. just buy the cheap ones. it didn't matter. sorry for the sloppy grammar, in a hurry!
here's resurrecting an old thread, but i ran across this thread in my study for what to coat my frame with. . .
I read bob's article and was pretty convinced towards PPG then i ran across this http://www.ppg.com/en/newsroom/news/...20101028A.aspx
here's something to be said when a national hockey teams uses the stuff.
I was painting a few small parts, and pretty much by accident I stumbled across a process that seems to work well. I had finished the POR process, and I didn't want to have to clean the spray gun for just a couple of small parts, so I grabbed a spray can of Rustoleum that I had on the shelf. I had to leave, so I sprayed the parts while the POR was still a little tacky. The Rustoleum bonded really well & the coating is tough as nails. I ended up doing the same for my inner fenders. So...maybe the question isn't POR versus Rustoleum...it should be POR and Rustoleum!
On my newer project truck (1989 f150) I chose tremclad (canadas rustoleum) due to the budget build I am doing. I think with proper prep it will be ok, but its really in a different category then por-15.
I used por 15 once on a truck and the gravel roads seemed to knock it off fairly fast, leaving me with rust showing again. That was after prep as per por-15's directions stated.
Could have got a bad can maybe? cause most guys I talk to love the stuff.
robertr
13
09-09-2007 08:29 PM
AXracer
40
10-31-2005 01:00 PM
halfdone
09-04-2004 07:29 AM
