Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 11-28-2011, 08:25 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
Garage is empty, add now
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Back in the Hood
Actually under the hood....... I bought my 9' flareside bed in Spokane a year ago, and bought the 59 F350 stake truck in Early September of this year. I had been looking for a correct vintage Ford with a 60" cab to axle dimension so I'd have something to mount this bed on. It required a different rear axle which I had collected, and then I decided to convert the front hubs so they'd be the same 8 lug pattern. Then I mounted the box, did a bunch of leaf spring work and after that I built a hd rear bumper. Somewhere during this frenzy, I got it running and left a bunch of stuff under the hood a bit wired and zip-tied and vice-gripped together. (most of you have seen pics of this rig, but never under the hood). Well, this afternoon as work in the shop was winding down, I disconnected the battery cable to pull the generator, but My temporary battery tray fell apart so I pulled it out and one thing lead to another and I started stripping stuff off under the hood. I guess I will fix the gen., re-plumb the heater I had by-passed initially and tidy stuff up in there. I did recover this cool windshield washer bag off the other fender and it was still half full. I remember at the beginning I was stepping on this weird pedal above the dimmer switch and spraying fluid all over the engine compartment. Sorry for the long post, I am just really excited about this fridge, It has really grown on me..........
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #2 (permalink)
Old 11-29-2011, 07:57 AM
ibuzzard's Avatar
ibuzzard ibuzzard is online now
We'll Always Have Poway..
ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.
Gary,you can probably locate enough parts to make your windshield squirters functional again.If NumberDummy sees this post,he'll probably give you info on who, if anyone, has parts to complete it.I have bought three complete kits over the years, the one now on my truck, plus the two spare kits on my parts shelf.They come up on eBay frequently, and at least the bag is reproduced,you can find them in the main parts vendors catalogs.Hardest to find is the foot pedal with the rubber bulb,which cracks.
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
" Show me your Tee-Hee, I'll show you mine."
  #3 (permalink)
Old 11-29-2011, 09:27 AM
GB SISSON's Avatar
When it squirted all over under the hood it was because a hose was disconnected. It seems to be functional as is. There is still plenty more to fix, but I have all winter, and it's what I like to do. My employees leave at 4:30 and my better half gets home at 6:00, so that's my easy truck time.
__________________
  #4 (permalink)
Old 11-29-2011, 05:55 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Not hard to find at all kiddo, when you know where to look. There's two different types, manual and electric. C Series Tilt Cabs used both these setups into the 1980's as did 1950/60's Passenger Cars.
btw: This is a later replacement bag. Originally, where it sez See-Clear and the windshield, instead of being opaque, was clear so you could see the amount of fluid.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #5 (permalink)
Old 11-29-2011, 08:56 PM
GB SISSON's Avatar
Dang, so mine is a reproduction? I thought since there was a 59 in the serial number at the bottom, it might have been original. That's ok, about 1/2 of my rag tag fleet, including this one doesn't even have wipers or ones that work. That's ok, on crummy rainy days I have other not so fun stuff to drive and this stuff lives in the shed. Here's a couple of the rag tag ones.
__________________
  #6 (permalink)
Old 11-29-2011, 09:11 PM
ibuzzard's Avatar
I need that old Ford !
It doesn't mean it's a reproduction(though it could be), only that it was a later replacement,Ford having changed the design. I think.
__________________
  #7 (permalink)
Old 11-30-2011, 12:25 PM
GB SISSON's Avatar
Craigslist find a couple years ago. I pulled it out of a shed on a farm in Ferndale Wa. His dad had put it in there 26 years before. I was driving it the next day. 1600.00 and ZERO rust. I'm gonna put the ford script flatbed that came on my F350 fridge on it soon.
__________________
  #8 (permalink)
Old 11-30-2011, 07:14 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
That is one beautiful truck.
  #9 (permalink)
Old 11-30-2011, 07:35 PM
GB SISSON's Avatar
Thanks, I have made a point not to wash it. The other side of the hood has a big ol' bird**** on it. I've worked it the last two days hauling lumber from my sawmill. It seems to like to get out now and then.
__________________
  #10 (permalink)
Old 11-30-2011, 07:56 PM
spurredon's Avatar
Yeah, it sort of looks like I feel. When I first get up I feel my knee joints are full of concrete but after I get moving along I limber up just fine. All old things need a little excercise once in awhile. By the way, you got that thing running kind of fast after sitting around for so long. I may have still been sitting inside of it making "vroom vroom", sounds for several days!
  #11 (permalink)
Old 11-30-2011, 08:04 PM
GB SISSON's Avatar
As an adult, my dad told me that when I was a kid I would get a new model car (or truck) and would stay up all night til it was finished. Can't teach an old dog new tricks. I actually bought a 6 volt battery on the way home that day and with this island living one sometimes has to wait hours for the next ferry, so I figured Id try to start it up on the trailer so I could drive it off. Therefore I kinda had a head start on the next day.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
