Best 360 4 barrel intake manifold - Ford Truck Enthusiasts Forums
Old 11-28-2011, 08:44 PM
kilich kilich is offline
kilich is starting off with a positive reputation.
What is a good 4bbl intake manifold to use for a Stock 360 with C8AE-H heads?
off what cars and years, and or who makes them?
Old 11-28-2011, 10:07 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
Either the "S" or the "T" intake. It was the standard iron 4 barrel manifold on the FE engines after 1966.
Old 11-29-2011, 02:55 PM
Quote:
I dont understand what "S" and "T" stands for
Old 11-29-2011, 03:36 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
It's just a letter cast into the manifold. A basic, stock manifold.
Pic:
http://home.windstream.net/bsprowl/I...SIntake1-1.jpg
Bantering about the same, with some info on the different manifolds. The "T" manifold is similar, but from later model year trucks iirc.
http://www.ford-trucks.com/forums/98...-manifold.html
Old 11-29-2011, 04:02 PM
Bear 45/70's Avatar
The "T" was the truck version of the "S" manifold on the mid 1970's truck engines.
Old 11-29-2011, 05:09 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
One small item to watch out for, earlier intakes, even those for closed crankcase ventilation, had a larger diameter thermostat. I used a 65 Galaxie intake on my 77 and found that out the hard way when I was looking for a water outlet for it.
Old 11-29-2011, 05:22 PM
Bear 45/70's Avatar
Quote:
No "S" or "T" intake has the large diameter thermostat. Mainly since they did not appear until 1966 when the small thermostat became standard.
Another note, all this whining and crying about the weight of these iron intakes, just how often do you plan on tearing this engine apart? Besides that when I was young like most of you, I lifted on and off the heavier CJ intake regularly on my race car. Grow some muscles.
Old 11-29-2011, 06:00 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
I've done the cast iron intake R&R a few times over the years, as well as head R&R on a FE. I have learned a few things along the way. Most importantly, a cherry picker is your bestest buddy in the world when it comes to getting the intake off. Sure, I *can* do it by hand, but why would I, when the picker is SO much easier......
Old 11-29-2011, 06:03 PM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is offline
Sleepy445FE is gaining momentum as a positive member of FTE.Sleepy445FE is gaining momentum as a positive member of FTE.
Agreed, the "S" or "T" will be the easiest to locate and cheapest to buy. These intakes are identified this way because aside from there casting number they have a large "S" or "T" cast on them. ex: casting # D4TE 9425 with a big "T" next to it. The "T" is marginally better than the "S".
There's also the C4 casting found on Thunderbirds and other passenger cars of the early to mid 60s (large thermostat housing) and the Edelbrock Performer, which are slightly better than the S or T, but they are harder to find or more money and you wouldn't notice much difference on a stock 360 between either of them and an S or T.
Which brings me to ask if you plan on keeping it a stock 360 or do you have future engine plans? If you plan on rebuilding this at some point and making 350+hp I would go ahead and start looking at aftermarket stuff or try to find a CJ intake. I built mine that way, piece by piece as I could afford it. First a Performer RPM intake, then heads, then a carb (couldn't use it at the time too much cfm), then finally the stroker kit and cam. Then that sat around while I scrounged up the money for machine work. lol This was spread out over 2yrs but eventually I got it done. If you have something like this in mind, it would be good to go ahead and plan out your build and start buying those parts as you can.
And Wulff, we lift heavy things because we're MEN *Tim Allen haugh haugh haugh* lol
Old 11-29-2011, 06:31 PM
Bear 45/70's Avatar
Quote:
Yeah, and a afternoon at the races and you need to change the stock intake out for the multi-carbed intake for a second class, means no cherry picker. Muscles work just fine and have for centuries. In my garage the the picker is or overhead hoist if great. But they just aren't that damn heavy, unless you are a ....................................little girl.
Old 11-29-2011, 07:36 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Me thinks Bear is dilusional among other things.
Old 11-29-2011, 08:51 PM
My dad and I pulled the intake and heads off his 352 last weekend.. No cherry picker or nothing.. Didnt weigh as much as people are saying..
Old 11-29-2011, 09:00 PM
It varies from 72-80lbs depending on what you have. No small thing but it's not too bad in a truck if you have the hood off. Lets you straddle the engine with feet on the inner fenders and just pick it straight up and put it straight down on install. But then I am pretty tall @ 6'3", maybe everyone couldn't do it this way.
If you have to lean into an engine bay and do it by yourself, it can be pretty rough. Learned that the first time. Hood comes off from now on! lol
A 12pack of brew and a buddy makes short work of it though.
Old 11-29-2011, 09:03 PM
haha. We have the hood on the truck still, My dad (5'11"), Me (6'2") each leaned into the engine bay on each side and lifted it up and over the radiator to get it out.. Rested it on the radiator to reposition ourselves and got her out..
Old 11-30-2011, 03:09 AM
tbm3fan's Avatar
tbm3fan tbm3fan is offline
tbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to beholdtbm3fan is a splendid one to behold
When I went looking for a 2bbl manifold, without egr for he 360 in my 65, I had to lift it off the block and slide it up over the radiator to get it out of the raised junkyard truck by myself (6'1" 170lbs.). Then when I put it on the 65 I used a 6 foot 2x4 with the manifold suspended in the middle and me on one end and my wife on the other end. By the time we lowered it onto the block it was getting dark under the hood but we managed. Used the standard cork end gaskets and got a perfect vacuum and oil leak free seal. Hopefully if it is on the ground one is good with dead weights lifts...
390 intake manifold Nick-1973-ford 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-07-2016 11:22 AM
Ford Fe parts compadibility? Duellym General Automotive Discussion 6 07-12-2015 09:07 PM
360 fe 4 bbl intake manifold hunt Zemmeron 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-19-2011 09:27 PM
Intake manifold hoses, what goes where? Big Skier FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 04-10-2011 01:19 AM
1974 360 enigne a1974cg47p FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 11-28-2006 12:03 PM
Tags
1970, 289, 360, 360e9425a, 390, barrel, f100, fe, ford, intake, manifold, maniford, sale, stock, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
