BANK#1 too lean & misfir cyl #2-Help with possible problems please
Old 11-28-2011, 05:33 PM
westflgator's Avatar
westflgator
westflgator is offline
My wifes 2003 F150 (5.4) started running rough, whether driving or at an idle. The code that I am gettting is this, BANK#1 too lean & misfir cyl #2. I changed the spark plugs out about 30k miles back. I have changed some of the COP's but no positive it this is one of them. When the others failed they didn't have the same symptoms. They would only run rough once I got into overdrive and was attempting to climb a hill or something of that nature. I know those were only weak, and this COP may have completely failed. Anyway I didn't know if the BANK#1 too lean code was a result of the misfire or the possible cause. I would appreciate any tips on trouble shooting this problem.
Thanks in advance
Old 11-28-2011, 07:24 PM
kbsupercrew's Avatar
kbsupercrew
kbsupercrew is offline
Number 2 cylinder is pretty easy to get to, unplug COP while running note change, then unplug injector on 2 note change, listen for click noise on injector running with piece of hose , this means power to it, still no luck , swap coils with cylinder 1, note code movement, no luck ,swap injector with cylinder 1 and see if code moves, you'll find it
Old 11-29-2011, 02:13 AM
phil6608's Avatar
phil6608
phil6608 is offline
Fix the misfire first and see if the lean code comes back.
Old 11-29-2011, 10:53 AM
westflgator
Thanks for the response. I will try the tests you recommended to try and determine which is causing the problem. I didn't know if there was a way to test the COP with an ohm meter but since it is fairly easy to get to #2, I with follow your advise. As far as fixing the misfire and then checking to see if the lean code disappears. I would assume that a misfire on that cylinder could be caused from the injector or the COP, so I was wondering if there was a trick to testing which one was causing the problem. Swapping them both one at a time with a known good should work.
thanks
Old 11-29-2011, 06:09 PM
kbsupercrew
Injector ohms are 13.5 to 19 , COP ohms are .55 ohms primary (conector terminals) and 5,500 ohms secondary( primary terminal to plug spring), fyi all could be good and still misfire due to clogged injector
Old 11-30-2011, 11:06 AM
westflgator
Thanks for the info, I will test the both of them and see what the resistance is and go from there.
Mvenem
3.0L V6
01-18-2016 04:59 PM
mtmcall
2004 - 2008 F150
01-16-2016 12:48 PM
Andrew7dg
1997 - 2003 F150
12-04-2013 08:30 AM
smitty403
08-11-2012 11:51 AM
roperjoe
1997 - 2003 F150
01-24-2012 08:37 PM
Quick Reply: BANK#1 too lean & misfir cyl #2-Help with possible problems please
