Flathead Aluminum Intake Manifold - Ford Truck Enthusiasts Forums
Old 11-28-2011, 03:52 PM
1951flatheaddave 1951flatheaddave is offline
1951flatheaddave is starting off with a positive reputation.
Hello, I have a 1951 F1 Flathead V8 with a cast iron intake. I found a guy selling an aluminum intake for a very reasonable price but he is unsure of the year. My iron one has 2 holes towards the front, oil fill and breather tube I believe, did the 48 and older or 53 and newer in take have these too? The aluminum one has these two holes as well so I think it is the same design but would rather be safe than sorry. I tried looking on Jegs and Summit for a comparison but they use the "representative image" for their intakes and they had both designs shown for older and newer engines and some that said they would fit from 38-53, maybe they are interchangeable and I just dont know it.
Thanks!
Old 11-28-2011, 04:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Canadian engines for some years in the 48-54 era used aluminum versions of the stock intake manifolds. I have one, paid about $75 for it as I recall. They weigh about 100 lbs less than the cast iron ones (not really but it feels like it). They also used cast aluminum timing covers, but those aren't necessarily a direct bolt on.
You "can" use a 38-48 car/truck intake manifold on an 8BA, but you lose the improved crankcase ventilation of the 8BA style manifold, and have to make some easy internal changes (removing a stovepipe that is under the manifold). You'd also have to use the early-style fuel pump stand and probably the pump itself, and use an early style pushrod.
It sounds like you are looking at a Canadian C8BA manifold; it's easy to tell as it will have casting marks "C8BA" or "C8RT" in plain view.
Old 11-28-2011, 04:18 PM
Thanks Ross, if it isnt the 48-53 style I am not interested. I am not looking to make all of those changes. Here is the link to the intake, let me know what you think.
Its the intake on the right
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old 11-28-2011, 05:02 PM
ALBUQ F-1's Avatar
postin' fool
I can't figure why he's selling the two together?? I'd tell him to throw the c.i. one away rather than ship it.
It's real hard to tell as dirty as the one on the right is, but it appears to 8BA and if he says it's aluminum, it's probably a Canadian intake. You can see the fuel pump stand behind the c.i. intake is the earlier style, and that carb looks like junk. If you want a Canadian intake, PM me and I'll give you the address for a source.
Old 11-28-2011, 05:11 PM
He said it has the casting "C8BA" on the intake. He said he would sell the aluminum intake seperately and just relist the cast iron one and the carb. He said for $20.00 he would include the shipping. He said he feels the carb is worth the most money and only really wanted $10.00 for each intake and $50.00 for the carb. So I thought for$20.00 it was worth the gamble. Thanks again Ross!
What type bolts old farmer Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 01-19-2016 10:40 PM
1951 V8 Flathead Fuel Pump Block Off 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 07-07-2015 10:45 PM
MSD Ready to Run Distributor in a 51 Flathead V8? 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 02-05-2012 06:53 PM
1951 f1 v8 4 soeed question 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-19-2011 05:38 PM
Engine Weight Info 4tl8ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 11-15-2008 08:00 PM
Tags
8ba, aluminum, factory, flathead, ford, intake, iron, manifold, manifolds, sale, unique, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
