6.7 OIL FILTER LOCATION
If you manage to knock the oil filter off, you need to write Bill Engvall so he can make you a sign! Seriously, it does seem to hang down, but the front axle offers a lot of protection for the filter. It would be virtually impossible to have a problem going forwards. I could see how something could happen in reverse, but again that would almost take a very careless act on the part of the driver.
I'm guessing, were this to somehow happen, breaking the filter off would actually cause major damage to the hardware holding it on or would the filter bend/tear off (being thinner metal)?
The compacted graphite iron is supposed to be fairly strong stuff though.
2. Oil pressure switch
3. Engine Oil Temperature (EOT)
sensor
sensor
on
I think this ties into the recent discussion about the oil pan... and they both hang down at the same level.
I'd think you'd hit the front axle arms first before anything. So if you guys somehow manage to destroy the oil pan and filter on your trucks then you must be totally ripping the guts out of the undercarriage when driving normal vehicles right?
You could have the oil filter behind a skid plate like on a Tundra... but how many times have I heard complaints from Tundra owners about having to pull the skid plate (which takes all of like 90 seconds, really) before changing the oil filter?
I think we want the thing right in the middle of the engine bay when you open the hood (like on the Navistar engines) and gravity drains the filter for you when you take it out ... but then you're looking at the open hood of a 6.7L equipped SD and you're wondering 'where the heck would I fit an oil filter in here?'
But for fun, let's consider the failure mode. The filter is made out of material thicker than a pop can but more or less like a soup can right? (You guys punch them by hand when doing oil changes so it's not THAT thick.) I think it would take the hit without ripping part of the engine block off, although spewing all your oil out in the process.
Trent is that a pic of the 2011 F350? or the tundra?
Either way its not likely that you can rip it off, I had an extra long fuel filter that hung below everything and I never even noticed dents on it. I don't do any serious off roading but there are dirt roads and rocky roads I drive on with no problems.
on
