6.7 OIL FILTER LOCATION
Old 11-28-2011, 03:19 PM
Rick Eady's Avatar
Rick Eady
Rick Eady is offline
HAVE ANY OF YOU HAD PROBLEMS WITH KNOCKING THE OIL FILER OFF, OR DAMAGING IT DUE TO IT'S LOCATION?
Old 11-28-2011, 03:28 PM
Hdslider's Avatar
Hdslider
Hdslider is offline
Haven't heard of not 1 person having a problem.
Old 11-28-2011, 03:44 PM
kper05's Avatar
kper05
kper05 is offline
No. I don't see how this is possible.
Old 11-28-2011, 04:16 PM
Biggziff's Avatar
Biggziff
Biggziff is offline
A few speculated early on that this could be an issue, but I've yet to read of it happening.
Old 11-28-2011, 05:11 PM
720Deere's Avatar
720Deere
720Deere is offline
If you manage to knock the oil filter off, you need to write Bill Engvall so he can make you a sign! Seriously, it does seem to hang down, but the front axle offers a lot of protection for the filter. It would be virtually impossible to have a problem going forwards. I could see how something could happen in reverse, but again that would almost take a very careless act on the part of the driver.
Old 11-28-2011, 05:47 PM
kper05's Avatar
kper05
kper05 is offline
I'm guessing, were this to somehow happen, breaking the filter off would actually cause major damage to the hardware holding it on or would the filter bend/tear off (being thinner metal)?
The compacted graphite iron is supposed to be fairly strong stuff though.
2. Oil pressure switch
3. Engine Oil Temperature (EOT)
sensor
Old 11-28-2011, 06:21 PM
Pacman51's Avatar
Pacman51
Pacman51 is offline
Come on guys....a screaming troll at his best. Joined in March 2011 and his first post is today and it's a internet "scream" about a nonexisting "problem". Troll.
Old 11-28-2011, 07:00 PM
Biggziff's Avatar
Biggziff
Biggziff is offline
I disagree....it was a legitimate question asked without any attitude that I could read.
Lots of low post count posters on here that aren't trolls.
Old 11-28-2011, 07:24 PM
Hdslider's Avatar
Hdslider
Hdslider is offline
I imagine there's alot of us when we 1st seen it thought oh this isnt a good design. But it has proved itself to be well thought out. No problem. My truck has seen some places I woulda thought I might tear up the filter, but it hasn't happened.
Old 11-28-2011, 08:11 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
Back before I joined this site, I used to come and read a lot, then one day it made me sign up to read any more, it was still a few more months after that before I posted anything I'm sure.
Old 11-28-2011, 08:48 PM
CornTruckDriver's Avatar
CornTruckDriver
CornTruckDriver is offline
Talking
Whats rong with being a troll? Popping out from under bridges and collcting tribute. And the outfits are so cool.
Old 11-29-2011, 01:14 AM
TRENT310's Avatar
TRENT310
TRENT310 is offline
I think this ties into the recent discussion about the oil pan... and they both hang down at the same level.
I'd think you'd hit the front axle arms first before anything. So if you guys somehow manage to destroy the oil pan and filter on your trucks then you must be totally ripping the guts out of the undercarriage when driving normal vehicles right?
You could have the oil filter behind a skid plate like on a Tundra... but how many times have I heard complaints from Tundra owners about having to pull the skid plate (which takes all of like 90 seconds, really) before changing the oil filter?
I think we want the thing right in the middle of the engine bay when you open the hood (like on the Navistar engines) and gravity drains the filter for you when you take it out ... but then you're looking at the open hood of a 6.7L equipped SD and you're wondering 'where the heck would I fit an oil filter in here?'
But for fun, let's consider the failure mode. The filter is made out of material thicker than a pop can but more or less like a soup can right? (You guys punch them by hand when doing oil changes so it's not THAT thick.) I think it would take the hit without ripping part of the engine block off, although spewing all your oil out in the process.
Old 11-29-2011, 08:34 AM
Rick Eady's Avatar
Rick Eady
OIL FILTER PLACEMENT
THANKS FOR THE AMMO. JUST ADDED NEW TRUCKS TO OUR FLEET. THE ASSIGNED DRIVERS HAVE CONTACTED THE OWNER , WANTING TO MODIFY BY ADDING REMOTE FILTER AND REMOVING LOWER FRONT AIR DAM AND MUDFLAPS.
Old 11-29-2011, 08:47 AM
DemonRace6's Avatar
DemonRace6
DemonRace6 is offline
Hi!
Trent is that a pic of the 2011 F350? or the tundra?
Either way its not likely that you can rip it off, I had an extra long fuel filter that hung below everything and I never even noticed dents on it. I don't do any serious off roading but there are dirt roads and rocky roads I drive on with no problems.
Old 11-29-2011, 02:51 PM
TRENT310's Avatar
TRENT310
TRENT310 is offline
That's my 2011. Note the plastic 1/3 turn oil drain plug and the composite pan that has stirred quite a discussion lately. I took pictures of the underside on day 2 while it was still clean so I can use it for demonstration purposes when making posts lol.
Quick Reply: 6.7 OIL FILTER LOCATION
