Oil Cooler O-ring kit - Ford Truck Enthusiasts Forums
Old 11-27-2011, 10:37 PM
Dodge/Cummins Dodge/Cummins is offline
Dodge/Cummins is gaining momentum as a positive member of FTE.
Does anybody sell an oil cooler O-ring kit besides Ford and Intl.?
I'm thinking no.
Old 11-27-2011, 10:38 PM
gatormccluskey's Avatar
gatormccluskey gatormccluskey is offline
gatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to behold
I have not found them anywhere else, sorry. $70.00 at Ford
Old 11-27-2011, 10:47 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
That aint too bad....
Old 11-27-2011, 10:49 PM
Its not hard to do, just messy
Old 11-27-2011, 10:50 PM
dieselaholic's Avatar
dieselaholic dieselaholic is offline
dieselaholic is starting off with a positive reputation.
Mine came in my felpro rebuild kit so they might have it.
How do you get both ends apart? I can only get the one end off.
Old 11-27-2011, 11:28 PM
typefour's Avatar
typefour typefour is offline
typefour is starting off with a positive reputation.
Dude ive got them in stock, gaskets and the correct orings . 40 shipped priority, I can get them out tonight if you promise to pay me.
Old 11-27-2011, 11:30 PM
typefour's Avatar
Quote:
The black ones ,if thats what they were wont last, get hard in 20k.
It will come but it is a bitch, soak with dish soap a while.
Old 11-27-2011, 11:44 PM
I have a complete felpro gasket set so I'd better double check and see if they are in there.....................duh.......I just assumed they would not be in the kit..
Fel-Pro aught to sell them seperately.
I had to clamp the cooler (steel tube) in a vise as tight as I dared and knock the filer header off with a long nylon block and nylon hammer.
The header on the other end came of with just the mallet.
I'm going to VERY GENTLY use the huge hydraulic press at my Dad's machine shop to reassemble it.
Old 11-27-2011, 11:46 PM
Quote:
I think that price totally freakin' sucks for four O-rings.
Old 11-28-2011, 12:01 AM
starmilt starmilt is offline
starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.
Tightwad, lol I'm right with you, but at least typefour price is more in line with what you would think. Then again, you could be working on a cat. lol KW here wanted 500 bucks just for the headgasket. lol
Old 11-28-2011, 12:07 AM
typefour's Avatar
I'm going to VERY GENTLY use the huge hydraulic press at his machine shop to reassemble it.
They should be in there. if not let me know.
Once its cleaned up and lubed it will push together by hand. and for petes sake dont use any silicone on the gaskets they will shred.
Old 11-28-2011, 07:37 AM
NorthernDiesel's Avatar
NorthernDiesel NorthernDiesel is offline
NorthernDiesel is starting off with a positive reputation.
I bought both the gaskets and the O-Rings from RockAuto.com
O Rings: Victor Reinz Part #GS33545 $6.57
Gaskets: FEL-PRO Part #ES70689 $3.39
Old 11-29-2011, 12:54 PM
Good info THANKS!
Old 11-29-2011, 01:04 PM
Onus's Avatar
Onus Onus is offline
Onus is gaining momentum as a positive member of FTE.
Victor Reinz sells all the gaskets and the o rings for these engines. Someone posted the o ring numbers. Check out their website they have plenty more. http://catalog.mahleclevite.com/lv/search.php
Oil cooler DavidLM11 1999 - 2003 7.3L Power Stroke Diesel 8 12-06-2016 12:14 PM
7.3L Oil Cooler O-Rings jspence105 Excursion - King of SUVs 9 11-24-2016 08:54 PM
Oil cooler gaskets and o-rings jjlrrw 1999 - 2003 7.3L Power Stroke Diesel 60 02-14-2016 11:40 PM
oil cooler rebuilding Fireman_dave Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 02-16-2011 09:13 PM
oil cooler o-rings, how big of a job? kent's f-350 1999 - 2003 7.3L Power Stroke Diesel 5 12-14-2008 10:51 AM
Tags
1999, 2002, 58, 73, 95, bronco, cooler, engine, f250, ford, gasket, kit, oil, oring, powerstroke, seal, set
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
