Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 11-27-2011, 09:27 PM
The Peddler's Avatar
The Peddler The Peddler is offline
1973 Ford F-250
The Peddler is starting off with a positive reputation.
Where to buy: Master Cylinder/Booster and Steering Gear Box?
The project has been stale too long, time to get on it again. While the motor is still out, I'd like to go-ahead and replace the steering gear box, brake booster and master cylinder.
I want new/reman parts. Are the parts from LMC ok? Should I just go to NAPA? On the scale of good/better/best, I'm looking for better +.
Hope to post regarding progress on my project again soon!
  #2 (permalink)
Old 11-27-2011, 10:03 PM
earthquake68's Avatar
earthquake68 earthquake68 is offline
Garage is empty, add now
earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.
Auto zone or any of the parts houses will have what you need. Here's the rub. ...these parts are 30+ years old and have been rebuilt who knows how many times. (no matter how shiny the paint is when you open the box) I just got done putting 4 gear boxes and NINE pumps in my truck and I STILL don't have power steering. The best I did was to mount a Chevy pump to my 300 six. That got me power steering for two weeks. It just went out again tonight backing in to the driveway.
Since my truck is haunted and refuses to have power steering, you shouldn't have the trouble I've had, ...just something to keep in mind.
__________________
Alan Fenstermaker
'79 F-150 300-6, 4 spd. 4x4
  #3 (permalink)
Old 11-27-2011, 10:20 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to all
For the steering gearbox, the one to go to is Redhead Steering gear in Seattle, WA
Steering Gears | Steering Gearbox | Rack and Pinion | Red-Head Steering Gears, Inc. They are one of very, very few places that actually rebuild the steering gear, correcting design flaws.
Most of the boxes you get aren't actually rebuilt, they're resealed the so called "spray and pray" rebuilts.
  #4 (permalink)
Old 11-27-2011, 10:23 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
1973 Ford F-100
My Garage
HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.HIO Silver has a great reputation on FTE.
I'd head to a wrecking yard for a booster. I picked one a couple of weeks ago off a 75 for $45 (with an MC) that had new nuts front and back and clean threads - signs of newness!). Plus the booster housing had nary a rust spot. Bring a vacuum kit (like a MityVac) with you to test on-site. I'm gonna use it for my 70 Lo-Buck Bumpside. Rebuild the MC or, if preferred, head to A-zone or Oreilly's and pick up a reman with a warranty. Napa is Ok too.
I wouldn't do LMC for MCs, wheel cylinders, nor calipers. I prefer to purchase locally available remanned parts cuz it's less hassle to exchange them if something goes wrong.
Steering box? Redhead or Benchworks.
  #5 (permalink)
Old 11-28-2011, 12:04 AM
2002fx4122's Avatar
2002fx4122 2002fx4122 is offline
1977 Ford F-150
My Garage
2002fx4122 is starting off with a positive reputation.
I got a booster and master cylinder from NAPA about 2 years ago and installed it in my dads 77 and it works fine, if I remember right it was about 100 bucks and came as an assembly, but you still need to bench bleed the master cylinder
__________________
-1977 F150 Custom
466 BBF and Ford C6
Restoration in Progress
- 2002 F150 Fx4 Lariat
5.4 triton, 4r70W, 3.55LS
Edge Evolution, Magnaflow duals, Gotts mod
  #6 (permalink)
Old 11-28-2011, 06:18 PM
1973 Ford F-250
Thanks for the heads-up on the Redhead, Mike. I live about 60 miles from there, I like what I read on their site, and they're a local business, so that's where I'll buy. The booster and m/c I'll get from NAPA probably.
Is there a good paint that will stand-up to brake fluid, for the m/c, or should I just leave it "natural?
  #7 (permalink)
Old 11-28-2011, 06:23 PM
7Ford6's Avatar
7Ford6 7Ford6 is offline
7Ford6 is starting off with a positive reputation.
If I'd known about this before I replaced my M/C and Booster, I would have done the Hydroboost conversion -- http://www.ford-trucks.com/forums/87...sion-done.html
Search the threads plenty of more info on em...
__________________
  #8 (permalink)
Old 11-28-2011, 07:12 PM
HIO Silver's Avatar
1973 Ford F-100
My Garage
Quote:
Give it as much protection as you can. Rusty MCs just look bad IMO.
Eastwood recently came out with a brake fluid resistant paint called Brake Gray Finally….A Brake Fluid Resistant Paint | Eastwood Blog
VHT recommends Nu-Cast enamels: Cast Aluminium (SP995), Cast Iron Grey (SP997). The Product Usage Guide for VHT spray paints from Speco Thomas
Otherwise, I'd shoot it with a high temp clear and quickly wipe up any spilled fluid ASAP. Another option is brake caliper paint.
__________________
73 F100 SB, 4x4, 390FE, NP435, NP203,+4 on 35s, 70 F100 LB, 2wd, 360 FE, NP435, 70K original miles, 01 F-150 SuperCrew Lariat 4x4, 5.4L, 01 PT Cruiser Limited (DD), 71 Pontiac Lemans Sport Convertible, 68 Mustang 200-1v, 65 Mustang 289-4v
  #9 (permalink)
Old 11-28-2011, 08:00 PM
OldStyle's Avatar
OldStyle OldStyle is online now
Rusty Roller
1978 Ford F250 4x4
OldStyle has a good reputation on FTE.OldStyle has a good reputation on FTE.
You can also change over to dot5 fluid; it doesn't eat paint. It is silicone based and has a second benefit because it doesn't absorb moisture. It's more expensive and can't be mixed with other brake fluid; ie: Dot3 or Dot4.
http://www.gabma.us/docs/dot5.pdf
__________________
1956 F600 352 (on propane) Boom Truck w/2 22t wenches
1964 F100 4x4 460ci C-6 3/4t springs 31 spline Lincoln rear axle front disks AC ect...
1973 F100 4x2 360 (DOA)
1974 F100 4x4 360 flatbed
1978 F250 4x4 429ci C-6 33's
Tags
1964, 56, booster, box, brake, buying, cyl, cylinder, f600, ford, forum, gear, gears, lincoln, master, power, rebuilt, redhead, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
