Diesel Fuel Additive?
I use stanadyne, I believe stanadyne is blessed by ford as well, I could swear in my '08 owners manual it mentioned it, but my memory aint so great either. I buy the 5 gallon can of it about once every 10 months or so, I used to buy the cases of 10 oz bottles, but I'd be buying them all the time, I saved about 12 of the bottles and just refill them out of the big 5 gal can now. I use it at every fill,it's funny too because people at the other side of the pump will like bark at me, and say you don't need that crap in the summer ya know, it's not going to gel up when it's 80 out, I used to start in about ULSD and lubricity, but now I just mess with their heads and tell 'em I get like 8 miles per gallon more when I use it though......
Diesel Fuel Additives - Stanadyne
HOME ABOUT US CAREERS CONTACT CORPORATE DEALER LOCATOR
Search
Fueling Innovation
Fuel Systems Precision Manufacturing Filtration Systems Diesel Fuel Additives
Frequently Asked Questions
Performance Formula
Lubricity Formula
Winter 1000
Performance Formula Jr.
Material Safety Data Sheets
Contact
Documents
Aditivos de Combustibles Diesel
Which Additive is Right for You?
99549 Fuel Additives Brochure
99039 Diesel Fuel Update
OEM Endorsements
99835 PF Brochure
99625 PF Comparison Charts
REACH Compliance: Stanadyne Performance Formula
Cost Savings Calculator
Cost Saving Calculator - Metric version
GM Approval of Stanadyne's Fuel Additive
Home / Diesel Fuel Additives Diesel Fuel Additives
The heart of the diesel engine is its fuel injection equipment and the major enemy of this equipment is poor quality diesel fuel. From our extensive research and testing and our experience in manufacturing diesel fuel injection systems, Stanadyne found that variations in diesel fuel quality around the world can adversely affect today's precision fuel injection systems. Poor quality diesel fuel can cause performance issues, premature wear, gumming of components, and plugged filters. To resolve these issues and to provide protection of the fuel injection system, Stanadyne developed its own line of diesel fuel additives.
Stanadyne diesel fuel additives are the only ones in the world that are:
Made by a fuel injection systems manufacturer
Tested and approved by major diesel engine and vehicle manufacturers
Proven to perform best in independent tests
Stanadyne diesel fuel additives protect and improve the performance of all diesel fuel injection systems including:
High pressure common rail
Unit injectors
Rotary distribution pumps
In-line pumps
Stanadyne diesel fuel additives comply with federal low sulfur content requirements for use in diesel motor vehicles and nonroad engines.
Stanadyne Diesel Fuel Additives can be purchased from all authorized Stanadyne service locations in the United States and Canada.
There are other limited locations throughout the world that carry Stanadyne Performance Formula.
Click Here to locate a dealer near you!
Search
Fueling Innovation
Performance Formula
Lubricity Formula
Winter 1000
Contact
Documents
OEM Endorsements
99835 PF Brochure
Unit injectors
In-line pumps
My dealer won't order the gallon jugs, not enough profit I guess. 20 oz bottles only, for $8 none the less. Personally I think the stuff is about worthless, but yet I still pour it in each fill up hoping it helps my inferior HPFP last a bit longer.
Time will tell if it helps any. I can say it doesn't help fuel mileage much, if any.
Here is the part number: PM22GAL
Andrew,
If your dealer does not think there is enough profit in the gallon size packaging, ask him how much profit he will make when you do not buy any product from him...and then buy your PM22GAL from a different dealer.
I was filling my Titan fuel tank yesterday with another 30 gallons of substandard US fuel. As I poured in the recommended dose of lubricant, I had to think back to the 70's when I had to mix the oil with the gas for my Arctic Cat snowmobiles...boy these new trucks have sure came a long way...
Regards
after reading the report on the lubricity improvements in the baseline fuel, and seeing where optilube rated, and then where stanadyne rated(which I've been using)- I'll be changing to the optilube as soon as my stanadyne is all gone. The price is about the same per tankful- and it appears that optilube does a better job based on that report
As to the gallon of PM22 additive - the local dealer here doesn't sell it either. I paid $11 or $12 each for the bottles, got 2 last time. I am thinking of ordering the gallon online but I don't know about shipping... any ideas? Has anyone ordered it from partsguyed.com?
#28
I also switched. But went with Schaffer for now, Opti-Lube was out of stock when I looked but I think they have it now. I would post that report here again if I knew how.
#29
Has anyone used "RBP’s High Performance Diesel Fuel Additive Enhancer", the folks at 4 Wheel Drive Parts store recommend this product,,,went to their web site, the claims seem too good to be true,,,10% mileage increase, cetane increase boost of 5,,,etc,,,,,,,,,looked at the report on Optilube,,looks good, but old report, looking for a new study by an independent lab, one that is ASCLAD certified, will let y'all know if I find anything
#30
