Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 11-27-2011, 12:38 PM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
1960 Ford F-250
My Garage
thundersnow70 is starting off with a positive reputation.
need new pins on the orphan fridge door
i am wondering if anyone knows a hard way to replace the pins in the door hinge? i know the really, really hard way that actually destroys the hinge, and i have never seen new ones so i am gonna try to repin a pair i saved off the old parts truck. i have thought about puncturing a can of wd40 , putting it in a bowl and soaking them for a few weeks. also thought about soaking them in atf. i could just spray them everyday for a month or so but i would really like to submerge them in something so i can walk away from them for a few weeks. just trying to make it easier when i get them in the press. hopefully it wont destroy the hinge this time.
__________________
52 F2 & F3 Merryman Herringbone
60 F250 4x4
63 F250 4x4 Flareside
Mark
I might be in a cage at the zoo, but I'm still king of the jungle!
  #2 (permalink)
Old 11-27-2011, 01:15 PM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
Garage is empty, add now
tbirdscott is starting off with a positive reputation.
You can buy wd-40 in a gallon jug rather than popping an aerosol can open. Instead try a 50/50 mix diesel and atf, works good on loosening up rust.
Another option is Evapo-Rust. Will remove every last spec of rust, then you can repair and paint it easily. About $10 a bottle last time I bought some and it should be enough to do both hinges and more.
Scott
__________________
1960 Comet mostly stock, summer DD
1979 Ranchero/Thunderbird 'Thunchero' 390 or 460 powered in the future...
1980-82 thunderbirds everywhere you look
1994 F350 IDI turbo getting a 1959 Mercury body transplant
1994.5 F250 PSD, 5spd 4" rancho on 35's
  #3 (permalink)
Old 11-27-2011, 01:44 PM
57icebox 57icebox is offline
57icebox is starting off with a positive reputation.
You could also try something like CLR. (calcium, lime, rust remover)
  #4 (permalink)
Old 11-27-2011, 04:14 PM
1960 Ford F-250
My Garage
thanks for the ideas. now that you say wd40 in a gallon jug i remember seeing those. thats probably safer than busting open a can. i have never heard of diesel and atf, might try that first just to see how good it works. thanks again. i will probably wait for it to snow so i can drive it around without the doors to keep the neighbors on their toes.
__________________
60 F250 4x4
Mark
  #5 (permalink)
Old 11-27-2011, 05:17 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by thundersnow70
I've never seen new hinges...
Here's three of the little darlin's...NOS
1957/60 F100/1100:
4) B7C-8122800-A .. Door Hinge-Upper/Lower Right Side-For Left Side, reverse the hinge pin / Obsolete
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
WESLEY OBSOLETE PARTS in Liberty KY has TWO = 606-787-5293.
No Ford Dealer, no other obsolete parts vendor has any.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #6 (permalink)
Old 11-27-2011, 08:32 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Quote:
My penetrate of choice is PB Blaster! A little Blaster and a lot of patients works miracles! A torch works wonders as well!!
  #7 (permalink)
Old 11-28-2011, 05:58 PM
fromnwmt's Avatar
fromnwmt fromnwmt is offline
1959 Ford F-100
fromnwmt is starting off with a positive reputation.
When all else fails add HEAT it can be your friend.... I ended up sawing top of pin and pushing/pounding downward since they were still on truck......
__________________
59-F100 custom cab, 74F-250, 2000 F350-super duty
  #8 (permalink)
Old 12-01-2011, 07:07 PM
1960 Ford F-250
My Garage
yea, im gonna soak them for a good long time and hopefully get them out without the heat. that will be option two. Bill, i assume those are new nos hinges and not just the pins, i might have to see what they want for them. also didnt know you could flip them right to left by taking out the pin. i did read that right didnt i?
__________________
60 F250 4x4
Mark
  #9 (permalink)
Old 12-01-2011, 07:59 PM
Ford Parts Guru
2013 Ford Escape
Quote:
Originally Posted by NumberDummy View Post
Here's three of the little darlin's = NOS
1957/60 F100/1100:
4) B7C-8122800-A .. Door Hinge-includes pin / Upper/Lower Right Side / For the Left Side, reverse the hinge pin.
What the 1957/63 Ford Truck Parts Catalog (available on a CD from hipoparts.com) sez to do...
__________________
Tags
b7c8122800a, doors, fridge, pin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
