Harmonic Balancer Repair Sleeve Replacement
I had to pull the harmonic balancer off the truck due to a little oil leaking out somewhere up there. How do I get the old repair sleeve off the HB in order to put the new one on? Is there a tool? If so where can i find it or what is it called? Also, how do I go about putting the harmonic balancer back on since the bolt wont be long enough to draw it in?
I ended up cutting it very carefully with a dremel. I went 99% through and then popped it with a screwdriver. Then I welded it back together and used it on top of the new one to tap it into place with a hammer. I will probably end up using the longer bolt trick to get the whole thing back on.
on
The damper uses a wear sleeve in its stock configuration and the seal is sized accordingly. The sleeve is a bit thicker than a standard Speedi-Sleeve. I removed my damper with ~190k miles and almost no wear on the sleeve. Just required a slight polish with emery cloth before sending it to Bill
quakerj
08-21-2013 07:08 PM
Bagbyknoter
11-24-2011 02:38 AM
dmueller71
12-18-2010 10:49 AM
