Coolant drips in front of my ford 6.0L - Ford Truck Enthusiasts Forums
Old 11-27-2011, 01:17 PM
ua-usa's Avatar
ua-usa ua-usa is offline
ua-usa is starting off with a positive reputation.
Hi guys I have a question for you if anyone has an answer would be awesome!!!
So i had coolant shooting from my reserve bottle under heavy long pulls. someone told me i had Plugged EGR cooler,
SO i went and ordered ERG DELITE kit and changed a OIL cooler while i was there. put it all back together, drove for few days, and today i notice a 5 inch puddle of coolant under front of my truck.
DID my water pump blow up? why whould it do that ? didnt had coolant leaking from there before my ERG delite kit and oil cooler was changed
Also it shows P0678 Cylinder 8 Glow Plug Circuit Error code, I did changed the glow plug, but i still have that code showing, truck starts good even with the code any idea on that one also.
Here are some specs on my 2004 F350 King Ranch 145000
Full Turbo back exhaust
Performance K&N Filter
Bully Dog Chip with Outlook monitor that i'm running on Low settings all the time.
Had ERG Delite KID and OIL cooler changed recently
Old 11-27-2011, 02:27 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
Could very well be your waterpump, mine was doing the same when it failed.
Old 11-27-2011, 08:06 PM
fomoco60's Avatar
fomoco60 fomoco60 is offline
fomoco60 is starting off with a positive reputation.
The 2 places I get leaks from whenever I work on the cooling system are the lower radiator hose and the hose going to the thermostat housing. Always ends up being a clamp, if you don't get them right back where they were they tend to leak.
Old 11-27-2011, 09:07 PM
abealex abealex is offline
abealex is starting off with a positive reputation.
About a week after I did similar work to my truck, I had a coolant leak from the water pump area as well. It was leaking from the lower radiator hose where it connects to the water pump. It was a new Ford hose with the attached constant tension clamp, but was not tight enough. I replaced it with a standard hose clamp and problem solved! Hopefully yours will be that easy...
Old 11-27-2011, 10:34 PM
Special Ed's Avatar
Special Ed Special Ed is offline
Special Ed is gaining momentum as a positive member of FTE.Special Ed is gaining momentum as a positive member of FTE.
Get your hand on a coolant pressure tester & pump her up. AutoZone rents them for free if you dont have one or are not interested in purchasing one. She will **** right away under pressure so you can pinpoint the leak. My lower radiator hose leaked twice untill I put a new hose on it & double clamped it.
Old 11-28-2011, 03:35 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift 05 f250 6 inch lift is offline
05 f250 6 inch lift is gaining momentum as a positive member of FTE.
i did similar work to my truck an my waterpump went to leakin.
Old 11-28-2011, 10:01 AM
Unrealo4's Avatar
Unrealo4 Unrealo4 is offline
Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.
Water pumps are cheap and easy on the 6.0. But I would check the upper hose connection on the thermostat housing. I could never get it to seal right away. The spring clamp Ford gives ya is garbage.
Old 11-29-2011, 10:16 PM
dlibson's Avatar
dlibson dlibson is online now
dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.
Your number 8 glow plug code is likely the glow plug controller. I've found that is often the case with those.
Old 11-29-2011, 10:51 PM
ua-usa's Avatar
Thx guys today i purchased waterpu p from auto zone 117$with lifetime warranty. Installed it today it was somewhat easy to do. I notice my old water pump propeller was rubbing inside back wall of the case, I guess my shaft of water pump got bad. Will wait overnight to see if I see any drops on the floor from my new pump installation. But yes after I put everything together the upper hose clamp was giving me problems until I placed it on the original place than it stopped leaking. I hope that fixed the problem.
About the glow plug #8 is there a DIY tutorial to fix it like ficm tutorial that worked for me. Soldered few things here and there and it works like a charm. .
Anyone seen anything like that.? Ot to buy new gpcm
Old 11-30-2011, 12:04 AM
dlibson's Avatar
I've always replaced them. Not sure if there is a fix or not...
Old 11-30-2011, 12:24 AM
ua-usa's Avatar
Thx Dlibson. i guess from next pay check im going to change that also. right now it starts with no problem no hesitation, but prob will notice the difference when cold days roles in.
04 6.0 deltas are high. what should i do jjbusa 6.0L Power Stroke Diesel 12 10-13-2015 09:08 PM
EGR Cooler, Bad Degas Cap? ruger761 6.0L Power Stroke Diesel 12 06-21-2012 12:31 PM
2005 F250 6.0 running rough at low RPM firebc31a 1999 to 2016 Super Duty 2 08-30-2010 04:20 PM
How to clean the Turbo hrszwspr 1999 to 2016 Super Duty 13 07-01-2010 01:11 PM
White smoke is it EGR cooler or Head Gasket fx4hauler 6.0L Power Stroke Diesel 13 08-16-2009 10:36 AM
Tags
06, 60, 60l, coolant, cover, f250, f350, fluid, ford, front, hose, leak, leaking, radiator, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
