02 f250 7.3l fuel pump help!!
Old 11-27-2011, 11:00 AM
capitanjo's Avatar
capitanjo
capitanjo is offline
hey guys i have another thread open if yall wanna read thru it maybe you can help me with my issue.. But on here i was wondering if someone can look under there truck.
An look at the line fuel pump an see which wire was the positive an which is the neg.. an maybe snap a photo..
Im on my second fuel pump thinking the first new one was bad an the second one is doing the exact same..
So if i can get a photo of what it looks like thanks guy.
Old 11-27-2011, 11:48 AM
woodnthings's Avatar
woodnthings
woodnthings is offline
Not sure what you are asking for? Are younot sure which one is power?
Are you not getting power to the pump? If so, you should check the inertia switch behind the passenger side kick panel. There is a hole there to check the reset button.
Old 11-27-2011, 11:55 AM
woodnthings
Here are a couple of diagrams for you too.
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
IIRC there is a + (battery) and - (ground) marked on the fuel pump body right next to the terminals.
If you are not sure which wire goes where turn on the key and you will have about 20 esconds to find out which is the + wire.
From the above schematics the + is pink/black and the - is black.
Also you should bench test the new pump to see if it runs.
Old 11-27-2011, 12:01 PM
nlemerise's Avatar
nlemerise
nlemerise is offline
I'd add that you should bench test to see if the pump actually pumps diesel...the motor of the fuel pump could turn, but not necessarily pump fluid (not likely, I know...but worth checking).
Old 11-27-2011, 12:17 PM
PaysonPSD's Avatar
PaysonPSD
Good point Neal.
Old 11-27-2011, 01:25 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
ALL Bosch pumps are the same and IIRC the positive is the lead with the smaller connector.
You CANNOT mix them up by design, because if you get it wrong, one side will fit sloppy and the other side won't go on at all unless you drill out the connector so it will fit.
You can see on my fuel pump the two different sized threads for + and -.
EDIT:
And if you look closely, you can see the + and - in the casting of the fuel pump outlet shoulder.
The + is the smaller stud on the left.
Old 11-27-2011, 02:03 PM
HD Rider's Avatar
HD Rider
HD Rider is offline
Tried to rep Ken for the schematics but I'm still in rep jail.
Old 11-27-2011, 02:45 PM
capitanjo's Avatar
capitanjo
fantastic thankyour for the picture that was one of the problems i had the wires were backwards.! thank you
Old 11-27-2011, 02:52 PM
capitanjo's Avatar
capitanjo
So my new problem that occured is the vehicle was struggling to stay on unless i hit the accelerator a little bit. Then it stayed alive. I let it idle for about 10-15mins let the juices flow. an when I put it in drive to take off it would hardly accelerate.
Old 11-27-2011, 02:54 PM
Kwikkordead
Well I'm surprised that you were able to get them connected at all backwards like that.
Does the truck run now?
Old 11-27-2011, 03:25 PM
capitanjo's Avatar
capitanjo
no MY message above states my new problem :/ lol
I do have an extra CPS Sensor.
So i will let switch them out. see if theres a difference.
any suggestions while im doing that?
Old 11-27-2011, 03:45 PM
woodnthings
Do you have a check engine light on or anything? Is it running rough? Sounds like you may have an oil pressure issue. Do you have the means o do some basic troubleshooting checks like fuel pressure and oil pressure? Possibly a way to retrieve codes?
Old 11-27-2011, 03:59 PM
capitanjo's Avatar
capitanjo
I switched the cps sensor. it did feel a lil better.
the rpms would still go up high an the speedometer would barely move.
It sounds like it wants to "go" it just isnt going very fast haha.
I may be able to do all 3 but not untill tuesday When im off of duty.
It started up beautifully didn't lag on the idle like it had done so at first.
there was no engline light.
Old 11-27-2011, 07:09 PM
HD Rider's Avatar
HD Rider
HD Rider is offline
How high do the rpms go? Is this a tranny issue?
Quick Reply: 02 f250 7.3l fuel pump help!!
