Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 11-27-2011, 10:32 AM
jdm5630 jdm5630 is offline
Garage is empty, add now
jdm5630 is starting off with a positive reputation.
control issue
We have taken several long trips lately and i have been noticing that at high speeds the expedition feels rally loose. Any sudden wind burst and i feel the expedition move really easy. If i pass a semi truck. I can feel the sudden burst of air as soon as i clear it. If i hit a small bump on the highway. I feel like i am going to fish tail out of control. Is it just the od the expedition thays causing this? Or is tjere something wrong?
  #2 (permalink)
Old 11-27-2011, 05:04 PM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
I'm moments ago back from nearly 500 miles in my '07 XLT. Gusty winds and rain. Truck ran smooth and steady the whole way across the PA mountains.
I'm running Bridgestone all season radials, not off road tires. 35psi all around.
-- Chuck
  #3 (permalink)
Old 11-28-2011, 01:04 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
check your shocks, tires and bushings. sounds like you've got some worn suspension components
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #4 (permalink)
Old 11-28-2011, 05:17 PM
My tires only have 12000 miles on them. I will check the bushings and everything else tonight
  #5 (permalink)
Old 11-28-2011, 06:03 PM
whitexltexpy whitexltexpy is offline
whitexltexpy is starting off with a positive reputation.
Check the upper control arms as well. I took a 3,000 mile trip this summer with my '07 that had only 45,000 miles at the time. I did not feel any issues, as I guess I was used to it, but when 2 other family members took turns at the wheel, they observed that the vehicle was "steering funny". The 3rd row passengers almost got sick from the constant moving back and forth from one of the drivers. I took it in to get the tie-rods checked (I live in MN, we have ALOT of frost heaves that cause issues with alignment), and it turned out the drivers side control arm was shot. I replaced both arms myself with MOOG units that have grease zerks. The stock Ford arms do not. The new arms solved my issues, and it is back to handling like new.
Mike
  #6 (permalink)
Old 11-28-2011, 11:51 PM
How can you tell if the tie rods are shot?
  #7 (permalink)
Old 11-29-2011, 01:06 AM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
jack up the front end
wiggle the wheel left/right. watch the tie rods and steering linkage. You shouldn't see any slop...slop = replace ASAP
take a long bar/stick and pry upwards on the wheel. check the upper and lower control arms. You shouldn't see any slop when prying either. If you see any movement...again replace ASAP
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
