PCV Valve F150 2004 5.4L V8
From what I have read in the forum, the PCV does not exist on the 5.4L. In it's place is a heater element that acts as an electronic control?
My source of confusion is my Haynes manual that says to replace it as scheduled maintenance. Question is does this heater element need to be replaced regularly? B/c from what I can tell it is expensive and difficult to locate for purchase on the internet.
Well if you have a 3valve engine you don't have a PCV valve but if you have a 4.6 2v motor you do have a replaceable PCV valve, but if you do it still is probably fine, just check flow, unless you never change your oil and it is sludged up your fine, But keep to motorcaft parts, stay away from all others.
