55 running board hassle
I'm having a heck of a time with these new running boards. The brackets are too low and not lined up with the holes in the running boards, it's a tight fit between the front and rear fenders. Has anyone experienced this hassle and if you where successfull what was your stratagy?
I'm thinking of using a comealong to align the brackets by forcing them to where they need to be(actual bending the brackets) any other ideas would be appreciated. I think removing the rear fender and aligning the running boards with the cab and box will make this go some what easier too!
When I had fiberglass running boards on my 55 I put a piece of 1x6 wood under it for more stability and to raise them up some. I would think if you bent the brackets it will be difficulty to get them to line up or be straight, I would slot the holes where they bolt to the frame before I bend them, my $.02.
When I had fiberglass running boards on my 55 I put a piece of 2x6 wood under it for more stability and to raise them up some. I would think if you bent the brackets it will be difficulty to get them to line up or be straight, I would slot the holes where they bolt to the frame before I bend them, my $.02.
on the 56 they are riveted on..
Sam
I'm not sure that slotting the brackets will help much, as the one bracket seems to need to go about a 1" forward and a 1/2" up while the other two only a half hole out, and go figure one is perfect but needs to come up about 1".
Just a quick question, did you install the running boards before the rear fenders? The reason I'm asking is that I have the 3" wider fibreglass fenders and once painted thinking that they will get scratched when trying to get them in the notch of the fender.
Before you start bending stuff, I would suggest taking a good close look to determine exactly what the problem is. Are the brackets themselves bent or damaged? Are you using inferior aftermarket parts? Steel or fiberglass running boards? I've always tried to make it a point of modifying or fixing the incorrect part, rather than bending up known good pieces to make bad ones fit. Doing that only means you end up with more bad parts.
My 2c.
My 2c.
All good advice, I thought I had picked all the good used parts for my running board brackets????? but they seem to my only issue. I'm thinking that some where sprung while others may have taken a side hit, not sure as I bought my truck without the running boards. They are new and seem well made from MF. Shimming and oblonging the bracket holes are great ideas once I get them close.
I thought bolting all my new parts on would be a walk in the park not the case all seem to need some kind of tweeking!
Sam
I had problems too!
Try this (quoting frompage 400) of the '56 F-100 shop manual:
To install the running boards, work from the forward side of the front fender, and insert the mounting bolts through the bolt holes, then slide the rubber bumpers on the bolts from the rear side of the front fender. Then position the running board on the support arms, and at the same time, guide the assembly into position so that the bolt holes (front side of running board) slide onto the bolts and against the rubber bumpers. Then install the washers and nuts and tighten them until the rubber bumpers begin to compress. Then install the running board to support arm bolts. Then last, install the four running board to rear fender bolts.
Before I had the shop manual, I pulled my running boards off of my 56' to simply install step plates and had a hell of a time getting them to line up to put them back on. I couldn't believe how they could be on and look so good, then I removed them , and then they would not line up to bolt back on! I finally got them on, but it took me and my son both pushing and pulling and sweating and to get them to go. So I have not tried the above, but if my memory serves me, had I done what he manual said, I am sure it would of been much easier!
You will get them installed and they will look good! And if you are thinking about step plates.....now would be the time to put them on!
My bedsides were per drilled, so I didn't have any choice where to mount the fenders. I had everything profit before paint. As I remember it, I bolted the fender to the running board and raised the fender ends on floor jacks til it fit the bedside holes. Then I mounted the brackets to match.
Sam
Sam
I worked with the painter to get this into the most consistent coverage by painting the outside of the big pieces together.. (front clip, cab, and bed).
Sam
I noticed from your pics that you painted the front sheet metal assembled, what did you do where the sheet metal over laped each other for paint? The reason I ask is that is what I want to do but don't want the mating pieces without paint, so either I do each piece seperate or prepaint these areas and then assemble for final paint.
then we mouted the doors on the cam and used seam foam tape to prevent paint blow in along the seam.. then painted the whole outside..
on the hood/front clip.. painted inside, under the fenders, up to the fender edge.. then set hood on front clip, and used the same foam tape to seal the gap on the hood, then painted the whole outside..
on the bed, we painted the bed assembled, but with the fenders on separate stands to not cause a buildup on the joint. painted under the fenders first.
see all the pics here http://s427.photobucket.com/albums/p...green%20paint/
one example
Sam
Also check your bed is mounted correctly - and hasn't been modified at the mounting points at some point in the past.
I also shimmed my brackets at the frame to account for fitting issues and also used small rubber shims under the running boards to ease proper final fitment and cushion the boards at the mounting point.
