Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-26-2011, 06:35 PM
curbill4 curbill4 is offline
Garage is empty, add now
curbill4 is starting off with a positive reputation.
Where am I screwing up with my setup?
On my 93 7.3 dually auto I have a twin tank system. I have 2 electric fuel pumps and a 3 way manual switch on the floor to send the right fuel to the right tanks. I have a centrifuge and I heat my oil to 160 and then run the wvo thru the centrifuge. I prefilter the oil thru socks before it goes into the centrifuge drum. One tank is a 50/50 blend of vwo/diesel. I am in SO FL and the temp does not go to below 45 degrees at any time. If I am going to run the truck in the cold (to me 45 is cold) I will just use diesel. I make a 500 mile trip with the truck over 4days. My oil comes right from the fryer into cubes. I have used this oil for 7 years and I tip the people who control how the oil is transfered. I also have used the same oil in our 300 mercedes with a 20% diesel to 80% wvo for the 7 year period. I have a little over 120,000 miles on wvo so I am comfortable with my oil. I have started up on this blend for 2 years now and have never used straight wvo in the truck. 2 weeks ago as I drove to the store with the truck I got about 1 mile from th3e house and the IP busted. In opening up the pump at the diesel pump repair place they found water and rust in the pump. How do I prevent this from happening again. What type of additive should I be adding to my tank? Should I add a water separator to the diesel side or should both tanks empty into the separator before the injector pump. I only got 10,000 miles on this pump. Any help would be appreciated.
  #2 (permalink)
Old 11-26-2011, 09:04 PM
TxFordGuy TxFordGuy is offline
TxFordGuy is starting off with a positive reputation.
Your stock tank should be Poly and should never get anything but diesel in it. Is you 2nd tank steel or aluminum? You should only use a SS or aluminum tank with WVO. Is your secondary tank heated? if not, that is another problem. Pulling the thick oil casues extreme wear on the pumps
__________________
2002 F-250 Lariat 4x4 CC, 4" Magnaflow SS Exhaust, Wix 6637, Petes Cover, DP-Tuner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
