Key fob programming problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-26-2011, 12:25 PM
stash46 stash46 is offline
stash46 is starting off with a positive reputation.
I purchased a new set of key fobs from Ebay and cannot get them to program. I apparently have some sort of dealer installed aftermarket alarm system. Instead of cycling the key, I have to push a small black button located under the dash. The horn will chirp 3 times to indicate it has entered programming mode. I can then push the lock button on each new fob and the horn will chirp once on each to indicate it has been programmed. After turning the key off to exit programming mode, the new fobs will not work. What is strange is the fact that I can program and deprogram the old fob using this method. The old fobs have the "FORD" logo embossed on them. The new ones don't but seller claims they will work with "any" Ford 3 button fob. Does anyone have any ideas on this? Oh by the way, it's on my 1999 F250 Super Duty.
Old 11-26-2011, 01:39 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
There were apparently some Ford branded aftermarket alarms installed by dealers. Chances are, if the alarm is aftermarket the fobs are also. Even though they say Ford.
Do the fobs you ordered look the same (besides the name) as the fobs you have? And why are you trying to change fobs. What is wrong with the ones you have?
Old 11-26-2011, 01:47 PM
key fob
The old and new key fobs do not look the same. The old ones are a little bit longer. The old fobs broke where the key ring goes which is the reason for replacing.
Old 11-26-2011, 01:49 PM
I suspect that the old fobs are different than the Ford OEM ones. You might see if you can find the aftermarket alarm module and see if it has the name of the maker on it. You might be able to get fobs from them.
Key Fob not programming ride_red 2004 - 2008 F150 6 06-15-2015 07:22 PM
2003 F-150 Remote start FOB troubles. ktkoch 1997 - 2003 F150 5 02-06-2015 12:12 PM
Need assistance programming new key fobs w/aftermarket alarm F350SDKammyo 1999 to 2016 Super Duty 0 10-24-2013 02:19 PM
Factory remote start doesn't work after new keys LucasMN 1997 - 2003 F150 3 10-12-2012 11:36 AM
Remote Start Key Fob 24kttop Expedition & Navigator 1 06-13-2010 06:18 PM
Tags
01, 1996, 2004, explorer, f250, fob, ford, key, keyless, program, programming, reprogramming, set, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
