where is the fuel filter in 2003 expedition - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 11-26-2011, 03:07 AM
chubbybubby chubbybubby is offline
chubbybubby is starting off with a positive reputation.
I have looked all over and can not find the fuel filter in my 2003 expedition with a 5.4.
Old 11-26-2011, 03:37 AM
TerryB99 TerryB99 is offline
TerryB99 is starting off with a positive reputation.
Quote:
I just changed mine on my 2000 Navigator today. It was under the driver's side rear passenger door. Up between the fuel tank and frame rail.
I needed a fuel line hose removal tool, and got a shower of gas, lol.
The filter was $10. Ford wanted $75, so told my wife it was my $65 savings shower, so was worth it, lol
Old 11-26-2011, 07:37 AM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
Before removing the fuel lines, release the line pressure at the schrader valve on the fuel injector rail. Fuel won't spray out when the line is removed but have a catch pan available to capture the residual fuel in the line and filter.
Old 11-26-2011, 08:48 AM
dlibson's Avatar
dlibson dlibson is offline
dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.dlibson has a spectacular reputation.
NVM, it's the newer ones...
Old 11-26-2011, 10:22 AM
Well found the hidden fuel filter. Was right between the gas tank and frame rail hidden under plastic cover that blended in with the gas tank cover.
Old 11-26-2011, 06:53 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Start the engine then pull the fuel pump relay or fuse and wait for the engine to die. This will relieve the fuel pressure from the fuel line. Do not reinsert it until you're done installing the new filter or the pump could turn on.
2003 expedition electrical problems donbrasher Expedition & Navigator 0 11-09-2016 01:15 PM
2003 ford expedition main fuse box or related problems Gotproblems Expedition & Navigator 7 01-29-2016 01:24 PM
cab filters? John Wallace 1997 - 2003 F150 1 05-02-2013 07:28 AM
Expedition Fuel Filter Location tmh1331 Expedition & Navigator 1 01-10-2009 12:24 AM
2003 Expedition production ? (nckracer) mgazak Expedition & Navigator 3 04-13-2002 03:02 AM
Tags
03, 2000, 2003, 40, expedition, f150, filter, find, fiter, ford, fuel, location, navigator, pictorial, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
