5.4 rear main seal leaking bad is there a easy fix?
Old 11-26-2011, 12:41 AM
jdhudall's Avatar
jdhudall
jdhudall is offline
I have a 1999 F150 5.4 auto and my real main seal is leaking is there an easy fix or do I have to pull the motor or trans to fix?
Old 11-26-2011, 02:04 AM
phil6608's Avatar
phil6608
phil6608 is offline
I think you have to pull the trans to get to it. ):
Old 11-26-2011, 02:25 PM
jdhudall's Avatar
jdhudall
jdhudall is offline
that sucks for a $5 seal do any of the stop leak products that claim to stop rear main seal leaks work??
Old 11-26-2011, 03:58 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Nope, the stop leak products won't help the seal. The only one that may is Auto Rx or Lubro Moly motor oil saver both are ester based and can renew rubber compounds.
Old 11-26-2011, 10:01 PM
KING-RANCH02's Avatar
KING-RANCH02
KING-RANCH02 is offline
dang if its leaking that bad you'll have to pull the tranny like phil said, i had that prob once
Old 11-27-2011, 10:55 AM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
PCV system plugged causing high crankcase pressures??
Old 11-27-2011, 11:07 AM
jdhudall's Avatar
jdhudall
jdhudall is offline
Never thought of that I will check thanks
Old 11-28-2011, 05:06 AM
LLADNAR's Avatar
LLADNAR
LLADNAR is offline
Also you may want to take the plug out of the bottom of the bellhousing and inspect to make sure it is the rear seal and not the oil pan. I have been a mechanic for a long time and 95% of the time when somebody thinks their rear seal is out it is just the oil pan gasket. Most of the time a bad rear main will get oil all over the back side of the flywheel/flexplate. I would make sure if i was you before you start tearing into it.
Old 12-09-2011, 09:48 PM
brokenleg's Avatar
brokenleg
brokenleg is offline
Easy way out is to sell the truck...............
WI Camper
03-24-2019 07:16 PM
SuperDuty93
15
11-25-2012 02:49 PM
95250mac
04-26-2011 04:08 PM
OutlawNomad
New Jersey Chapter
04-07-2010 08:07 AM
low 350
01-22-2004 07:10 AM
Quick Reply: 5.4 rear main seal leaking bad is there a easy fix?
