Oil & Lubrication
Whats your oil of choice?
Old 04-05-2012, 07:08 PM
Scooter70's Avatar
Scooter70
Scooter70 is offline
Frantz makes a good filters for cars. Look at Gulf Coast 2-1/2 gallons additional oil. Big difference.
  #47
Old 08-20-2012, 03:18 PM
SyN's Avatar
SyN
SyN is offline
Pennzoil Yellow Bottle 5W-20 & 5W-30... With all the Moly-Boron-Calcium-Phos-Zinc that a motor could want with 5K mile OCI... 5qts of either with 2qts of Pennzoil Ultra 5W-20 makes our 08 5.4L 3V PURRRR!! BUT!!! M1 HM 5W-30 is an Awesome Oil as well according to what it's VOA shows.... One of M1 robust additive packages...
  #48
Old 08-31-2012, 05:06 PM
1991F35075L's Avatar
1991F35075L
1991F35075L is offline
when I have money its usually mobil one synthetic, but now that I am always broke its autozone brand 10w-30.
  #49
Old 09-01-2012, 06:45 AM
mistakenID's Avatar
mistakenID
mistakenID is offline
@Scooter70, Did you run the spinner bypass on that Mack? My dad ran a spinner on his Freightliner with the 60 series Detroit back in the 90's using Mobil 1. Changed and cleaned filters @ 15,000, add makeup oil.
Detroit pulled the engine down at around 350,000 miles and said there was barely any measurable wear on the engine.
Pretty amazing!
  #50
Old 09-02-2012, 08:01 PM
boxcar_tommie22's Avatar
boxcar_tommie22
boxcar_tommie22 is offline
i have always used red line products. all my fluids are red line
  #51
Old 09-04-2012, 11:02 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Bad Bad Leroy Brown is offline
Depending on the vehicle, I usually use M1 high milage, maxlife, or any of the shell rotella products.
  #52
Old 09-05-2012, 07:12 AM
Ed's Avatar
Ed
Ed is offline
Wink REDLINE OIL PRODUCTS & Power Steering "Whining!"
=boxcar_tommie22;12229562]i have always used red line products. all my fluids are red line
Boxcar Tommie; I love RED LINE's POWER STEERING FLUID. True story; Red Line's Power Steering Fluid was the ONLY, repeat ONLY PS fluid to quiet the common Ford power steering "Whine / Chatter" in my '87 Ford Aerostar XLT.
There was nothing wrong with the power steering, the rack or the pump. For some reason, the power steering on Fords, Mercurys and some Lincolns of the 80s and early 90s had an unmistakenable "whine". Tempos, Tauruses, LTDs, Thunderbirds and Cougars, Fox Mustangs ect. - I could tell those power steering whines without seeing the car first - it was a Ford product!
RED LINE Power Steering Fluid was the only fluid that actually quieted that PS "whine". Not completely eliminated, but much quieter. Even Ford dealer mechanics of that era simply shrugged their shoulders and said it was "the nature of the beast" when it came to customer complaints from 80s era Ford products.
RED LINE OIL is very popular with "car guys" here in Northern California.
Ed
  #53
Old 09-13-2012, 07:17 PM
Muffinman's Avatar
Muffinman
Muffinman is offline
Mobile One EP and Fram Ultra Guard filter, Both good for 15K miles under normal use. Which to me means 10K miles.
  #54
Old 09-13-2012, 09:31 PM
camp nh's Avatar
camp nh
camp nh is offline
I use Shell Rotlla T 15-40. I change every 10,000 miles and use a napa gold oil filter.
I drive commercial truck and we use Shell Rotella T. Our mechanic has no problem with this oil.
  #55
Old 09-15-2012, 12:20 PM
bigdaddyII's Avatar
bigdaddyII
bigdaddyII is offline
I try to use either Mobil 1 or Pennzoil Platinum where possible. Here lately it's been the Motorcraft semi synthetic that the dealer puts in.
  #56
Old 12-13-2012, 06:42 PM
EwagonJeff's Avatar
EwagonJeff
EwagonJeff is offline
Amsoil, their top 0w-30 in everything, from my old 577 hp(dyno'd at rear wheels) 460 to the daily drivers. Change the oil once a year which usually amounts 3k on my Galaxie, 8-10k on my daily driver (2 weeks now a '98 E150) and the 16-18k on the wifes Saturn.
  #57
Old 12-24-2012, 07:49 PM
SDTriton250's Avatar
SDTriton250
SDTriton250 is offline
Mobil-1 5w-30 every 5k miles. Mobil-1 5w-20 in the Fusion and Mobil-1 20w-50 in the Harley. Mobil-1 10w-30 in the mower and as a gun lube.
  #58
Old 12-24-2012, 09:24 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
I have 3 oils that I use , depending on app . Rotella 15-40 , Castrol sae30 ,and Motorcraft synthetic blend .I also use some addatives in my 50 and 53 .
  #59
Old 01-03-2013, 10:45 PM
Ding126's Avatar
Ding126
Ding126 is offline
I change the oil on my F350, 4x4 (6.4) every 3-5k miles. I use motocraft, Rotella T..I was considering using synthetic Mobile 1 for diesels..but really, would there be any advantage of using a synthetic when I am changing every 3-5k??
  #60
Old 01-03-2013, 11:15 PM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
In a word, no. Synthetics, especially the primarily PAO ones like Mobil and Amsoil shine in extreme arctic cold. Even on the Donner summit, NorCal does not get cold enough to make a difference. Rotella and Delo are so good there is really no reason to use anything else. Unless you are willing to go 10-12k miles, just forget about it.
Quick Reply: Whats your oil of choice?
