71 360 timing chain help
You can lay the cover on a bench, and drive out the seal with a punch. To install the new seal, go purchase a seal driver set.
10 Piece Bearing Race and Seal Driver Set
and apply a very little amount of grease on the circumference of the seal, and the inner rubber and carefully drive it in. If you can not find a seal kit, then you can use a piece of wood, but be careful or you will damage the seal. You are probably going to wash the cover in a parts washer and dry it with air, then paint the outside a nice shade of blue, or chrome...I job well done is appreciated by all.
timing set should be here tomorrow painted the cover and front engine mount while i'm waiting for it to get here got the old front seal out by using a screwdriver and a hammer to pound it out came out without having anything messing up waiting for paint to dry to install new seal i may try to buy a seal driver thanks for the tips on giving it a small amount of lube when installing i lined up the timing marks like yous said does this look right? now just pull these off and install the new with the dots lined up like these?
got my new timing set have a question before installing the crank sprocket has 3 makings a circle triangle and rectangle which should i line up with the cam sprocket should i use the 2 circles? heres a pic of it in the box is these the marks how i should put it on my moror just as it sits in the box?
You are welcome. There are many on this website that could help you on your questions. I am not a FE guru, and have learned from others. Unfortunately, some of the high performance guru's like Barry and Maxtor and others do not post here anymore. I learned a ton from them, and am still learning. You can play it forward and teach others the things you learn.
got the rest of my parts now i can get this thing back together got the new timing set on and about to put the cover on took a pic of the new set on and wanted to make sure everythings right or if i should do anything else while the cover is off also i took a pic of the old worn out set check out the grooves in the sprockets.
Yes it looks good. Did you remember to put loctite on the cam retaining bolt?
The ware on the gears is normal for a very high mileage fe. Where is your oil slinger? Running a FE without one could cause those deep grooves even at low mileage.
http://www.ebay.com/itm/NOS-Crank-Oi...sories&vxp=mtr
Xwarrior86
10-08-2015 11:34 AM
cowboy_tevlin
05-17-2008 03:25 PM
ReverendMachine
03-12-2007 10:26 AM
