axle weight capacity - Ford Truck Enthusiasts Forums
Old 11-25-2011, 01:31 PM
Hellonwheels's Avatar
Hellonwheels Hellonwheels is offline
Hellonwheels is starting off with a positive reputation.
i have a dana 60 out of a 85 f250 a 10.25 out of an 87 250 laying around, my problem lies that i plan on using one of the to go under a welding trailer im making but i want to pick the strongest one. i looked up the 10.25 with an axle code of 39 and the weight rating is only 6250 where as my one ton dually truck has what appears to be the identical rearend with an axle code of 45 and its rated for 7400 pounds. What is the difference between the two, i need to have the heaviest axle i can get under the trailer since i think it will probably weight around 7500 pounds loaded!
Max weight / towing on the 6.7L ?? my996duc1 6.7L Power Stroke Diesel 50 01-01-2012 12:56 PM
What is my towing capacity? Pete Roberts 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 26 02-14-2011 03:55 PM
what rear axle do I have ? blackjack8900 1999 to 2016 Super Duty 2 01-30-2006 09:30 PM
Changing to a 1 ton dually rear end??? priley 1987 - 1996 F150 & Larger F-Series Trucks 12 02-14-2001 10:57 PM
Questions about Ford 10.25 Rear axle BlackSheep Offroad & 4x4 1 04-24-2000 08:08 PM
Tags
1025, axle, capacity, compare, f150, f250, ford, rating, truck, trucks, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
