Roll Pan for '49 - Ford Truck Enthusiasts Forums
Roll Pan for '49
Old 11-24-2011, 10:37 PM
divermo's Avatar
divermo divermo is offline
Texan
divermo is gaining momentum as a positive member of FTE.
Roll Pan for '49
Looking for a rear roll Pan for my '49. anyone know who makes or sells any.
Old 11-25-2011, 07:24 AM
tlb's Avatar
tlb tlb is offline
tlb is gaining momentum as a positive member of FTE.
Give Hot Rods Trucks a call. That is were i got mine. You can get them with or without a recess for the license plate.
Old 11-25-2011, 08:22 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
If your truck is stock, Mack Products, Moberly MO has what you want.
Old 11-25-2011, 10:17 AM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is offline
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
I beleive mine came from Dennis Carpenter
Old 11-25-2011, 11:27 AM
Jimmy49Ford Jimmy49Ford is offline
Jimmy49Ford is starting off with a positive reputation.
Thumbs up
Thats a pretty picture. What size tires do you have wedged in out back? I have some 295/50/15's that about similar to those. Pretty tough looking.
Jim
Old 11-25-2011, 05:38 PM
FTE fan
Quote:
Jim
Good eye ,you got it 295/50/15s
Old 11-25-2011, 07:11 PM
divermo's Avatar
Texan
Thanks Everyone, Ya'll are the Best
Old 11-25-2011, 09:21 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Quote:
Quote:
Thanks for the info on the roll pan. By the way, are you still running the stock rear axle? I'm liking the way those tires sit in your fenders and they look really good with the roll pan.
Old 11-25-2011, 10:39 PM
FTE fan
Quote:
No its not the original rearend i dont think. 2 pos back put in this 10 bolt, so i had the wheels made with 5 1/2 "" back space, wich is what you see. There is still a few inches of clearence. Id like to bring the wheels in a littel more, maybe bigger wheels, maybe just less backspace, maybe shorter houseing with tubs, I dont know. I guess the first step will be to to inspect the rearend and see what it is, and what shape its in.
Old 11-26-2011, 09:40 PM
Thumbs up
Hey Jim,
If you don't mind me bugging you again, what size wheels are you using with those 295's? I currently have 8" (wide) wheels with a 4" back spacing. The problem is, they are an older aluminum style and no matter what I try, I have one that leaks air pretty bad at the bead. I've re-mounted it, bead sealer, etc. with no luck. Do you run a 10" wide wheel? Mid-Fifty offers an version of the stock steelies that are 15 x 10" with a 5" back spacing, but real estate tucked in that rear fender is already getting scarce. Let me know if you have any opinion/knowledge on this and what you're running. If you wouldn't mind, I'd love to see some more pictures of these tires/wheels on your truck!
Thanks!
Jim
Old 11-26-2011, 11:18 PM
FTE fan
Hey Jim,
Thanks!
Jim
Yes my rims are 10" wide with 5 1/2' backspaceing, I believe i had them made up at Stockton wheel. I checked the BF Goodrich chart and it recomends 8' to 10' rims on 295/15s, 9.5" rims will give a tire width of 12.2". Im sorry but I dont know the width of my rear axels. PS I just found an old note in a box of reciepts , and it has the backspaceing as 4 1/2", Im not sure but I think there 5 1/2" Backspaceing. If you need to know anything super accurate send me a PM and Ill go measure whatever you need no problem, its just dark and cold at the moment.
Oil pan bolt size ? roadrash63 Ford Inline Six, 200, 250, 4.9L / 300 1 10-12-2016 01:16 PM
300-6 oil pan bolt size ? roadrash63 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 10-12-2016 01:15 PM
Roll pan and trailer hitch dwil 1967 - 1972 F-100 & Larger F-Series Trucks 5 08-19-2014 06:48 PM
roll pan with a hitch? meborder 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-01-2012 07:19 AM
roll pan for a 1971 f-100 mjsizzle 1967 - 1972 F-100 & Larger F-Series Trucks 10 05-15-2008 09:59 AM
Tags
1949, carpenter, dennis, f1, ford, fortys, goodrich, pan, rear, roll, rolled, sealer, surface, truck, trucks, tubs, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
