squeaky belt
Old 11-24-2011, 05:36 PM
almonyspm1's Avatar
almonyspm1
almonyspm1 is offline
squeaky belt
i know it sounds a little stupid but i cant get this thing to stop squeaking. i have replaced the tensioner and belt. it was fine for a little bit but it started squeaking again! my uncle told me to take some sandpaper to the bottom while it was running and that didnt work and then he said to spray a tiny bit of wd 40 while its running to see if it would take some rust of the pulleys. idk what else to do, it doesnt stop. help me
Old 11-24-2011, 05:39 PM
Edgethis's Avatar
Edgethis
Edgethis is online now
SANDPAPER!!!!! that sounds like a terrible idea. Maybe I'm too young to know that "trick"
Hit it with some WD40, it'll stop squeaking (watch out it'll fly everywhere). You can also get some fancy "belt-dressing" at a parts store too.
Might look into see what exactly is squeaking, just know the WD40 is usually just a band-aid fix.
Old 11-24-2011, 05:45 PM
almonyspm1's Avatar
almonyspm1
my uncle told me to never use belt dressing. he said if you have a squeak it will just make it so it doesnt go away. ive been hearing about these gatorback belts. whats good about them?
Old 11-24-2011, 05:48 PM
Edgethis's Avatar
Edgethis
The gatorback belts are nice, I have one. Supposedly less resistant to cracking and stretching.
Old 11-24-2011, 05:52 PM
rikard's Avatar
rikard
rikard is offline
I had to sand the water pump pulley and I used a GY Gatorback and later a Gates belt as replacements. The cheapo belts do tend to make noise but I never had one fail. The tensioner and clutch fan are other sources of noise.
regards
rikard
Old 11-24-2011, 05:53 PM
almonyspm1's Avatar
almonyspm1
alright ill give one of them gators a try. thanks for the input. happy turk day!
fordinmudd
04-05-2011 03:36 PM
74baja
11-02-2009 04:37 PM
seventyseven250
General Automotive Discussion
04-03-2009 03:40 PM
I6power
13
06-26-2007 08:50 PM
Brians97F250Crew
01-12-2007 03:49 PM
Quick Reply: squeaky belt
