Modular V10 (6.8l)
first oil change
Old 12-23-2011, 10:18 PM
Sand_Man's Avatar
Sand_Man
Sand_Man is offline
Another 5w-20 Motorcraft oil and 820S Motorcraft filter user here. I buy the 5 qt jugs only. You save money over buying single quarts, and if you buy two now, then you only have to buy one the next couple times and you always have a little on the shelf in case you need to add a bit between changes. Also, my truck uses about 3/4 of a quart between changes (5K miles) so I check at every fill up without exception. It only takes a second and since I fill up once a week, it helps me monitor any unusual consumption.
TCNashville
2017+ Super Duty
29
04-13-2018 06:49 PM
4x4countryboy
84
11-16-2012 05:05 PM
beforeiforget761
2004 - 2008 F150
04-13-2008 10:05 PM
tkd
Oil & Lubrication
29
03-01-2007 06:45 AM
dannyo
12-20-2005 09:28 PM
Quick Reply: first oil change
