6.7 engine block heater - Ford Truck Enthusiasts Forums
Old 11-24-2011, 11:02 AM
11red250 11red250 is offline
11red250 is starting off with a positive reputation.
Hey guys how bout a little help. I bought a 250 6.7 this spring thinking all diesels come with a block heater. Well this one does not, can not find one on the web as im sure i could install it myself, to new i guess. Eany ideas what the dealer would charge? Its starting to get cold here in Ohio and it takes forever for this beast to warm up. Thanks
Old 11-24-2011, 11:20 AM
Andrew010's Avatar
Andrew010 Andrew010 is offline
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
My truck also came without the block heater, but the dealer lied to me and said it had one. I didn't double check before taking delivery and like you, figured all diesels have one right. Found out when I was installing my plow mount, I don't have a block heater. I called my salesmen and he told me they would put one in for $450 (parts and labor). I ended up taking to the sales manager and he gave me a block heater at no charge, since the truck was supposed to have one to begin with.
In short, service told me it was about $250 for parts and $200 for labor. If I remember right it was something like $145 for the cord and $100 for the element itself. Call your dealer to find out for sure.
Old 11-24-2011, 11:30 AM
Thanks Andrew, wow 450.00 seams very high. The one they gave you at dealer, did you put it in yourself? I would think is a fairly easy install on those. Think i will go down to the dealer saturday and try to get one as they all should be stock factory items IMO.
Old 11-24-2011, 12:20 PM
gsxr1300 gsxr1300 is offline
gsxr1300 has a very good reputation on FTE.gsxr1300 has a very good reputation on FTE.gsxr1300 has a very good reputation on FTE.
does anyone know the parts numbers needed?
Old 11-24-2011, 01:07 PM
Painted Horse's Avatar
Painted Horse Painted Horse is offline
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
Previous generation of Powerstroke engines allhad the element in the block, The option was just to get the cord. The 6.7L is the first powerstroke to not come standard with the element installed. ( it is standard in about 14 cold weather states). I ordered my truck with out the block heater, assuming if I needed it I could just buy the cord like my previous 4 Superduty trucks. Not so.
The install involved pulling the plug from the block and inserting the new element and then attaching and running the cord. There will be some fluid loss when pull the plug. I've heard around high $300 for the going rate, but have not priced it out myself.
Old 11-24-2011, 01:42 PM
Andrew010's Avatar
Quote:
$450 was installed. The dealer decided to go ahead and give my the heater and install it at no charge.
The parts had to be ordered and took 3-4 days to get in. I was surprised neither the element or cord was in stock and had to be ordered.
Old 11-24-2011, 02:01 PM
jfritz_drfritz jfritz_drfritz is offline
jfritz_drfritz is gaining momentum as a positive member of FTE.
The block heater will help as a starting aid if it is v cold, but makes little difference in the time it takes for the the truck to throw heat. For that, the diesel fired block heater is the optimal solution (espar, Webasto)
Old 11-24-2011, 02:02 PM
CascadeF250's Avatar
CascadeF250 CascadeF250 is offline
CascadeF250 is gaining momentum as a positive member of FTE.
Its a shame it costs that much after the fact. I ordered mine with the heater and if I remember correctly it was a $75.00 option. I probably will never use it but at least it is there if I need it.
Old 11-24-2011, 03:03 PM
SCORPIO26 SCORPIO26 is offline
SCORPIO26 is starting off with a positive reputation.
It was only a $75 option according to my window sticker. I'b be pissed if they wanted $450 for a $75 option.
Old 11-24-2011, 08:53 PM
720Deere's Avatar
720Deere 720Deere is offline
720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future720Deere has a brilliant future
I specifically ordered the block heater on my truck. The $75 charge shows up on my window sticker, yet it never got installed. 13 months later I still don't have a block heater. I only travel 9 miles back and forth to work and it would be nice to have the extra heat in the motor before the truck starts. I guess I will have to go argue with the dealer sometime soon and get this straightened out.
Old 11-24-2011, 08:59 PM
jack_pine's Avatar
jack_pine jack_pine is offline
jack_pine is starting off with a positive reputation.
Quote:
That's bs. I also ordered one and will not be happy if it does not show up. Why so long to get this resolved?
I love them and have them on my 04.
Old 11-24-2011, 09:03 PM
Take your truck, bill of sale, window sticker and go back to dealer and demand that they install your block heater FREE OF CHARGE, since you've already paid for it.
Old 11-24-2011, 09:40 PM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to beholdPowerStrokeHD is a splendid one to behold
A couple of options for those wanting to install the block heater...
OEM option...
Element - Ford P/N: BC3Z-6A051-A (MSRP $30.43)
Cord - Ford P/N: BC3Z-6B018-C (MSRP $135.77)
You can pick-up the element and cord online from places like Tousley or Tasca for around $110 plus shipping.
Another option at half the price or less is a ZeroStart (Phillips & Temro) block heater kit. The only difference here is the cord is a generic one, so you will have to route and secure it as you choose. It does not have the wire loom and hangers like the Ford OEM cord. Ford sources the OEM heaters from P & T.
The ZeroStart P/N is 3500069 and you should be able to pick up the kit for $60 or less.
Old 11-24-2011, 10:20 PM
Andrew010's Avatar
Quote:
OEM option...
My dealer must mark up the parts a bit more. They quoted me almost $100 more for the parts alone...
Old 11-24-2011, 10:53 PM
Indigofarm Indigofarm is offline
Indigofarm is starting off with a positive reputation.
Great info powerstroke. Thanks
93 7.3 IDI Wont' Start Papa_Smurf Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 02-22-2016 11:44 PM
WTB FE 360/390 Engine Block - Ohio/Indiana Area VitaminC WTB - Parts & other 0 07-08-2015 07:05 AM
6.7L Block Heater grippy6176 6.7L Power Stroke Diesel 3 05-20-2015 06:21 PM
Best place for alignment and tire size correction JetExpress_6.7 6.7L Power Stroke Diesel 22 05-01-2015 11:51 AM
Another Ohio truck meet! Sunday, June 3rd Monster-4 1999 - 2003 7.3L Power Stroke Diesel 8 06-05-2012 08:37 AM
Tags
2011, 2012, 67, bloc, block, chord, diesel, engine, f250, f350, ford, heater, install, installing, location
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
