Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 11-23-2011, 09:25 PM
TCAS007's Avatar
TCAS007 TCAS007 is offline
2007 Ford Expedition
TCAS007 is starting off with a positive reputation.
Electronic problems after battery change
Hi!
My Expediton had a dead battery and I did the following.
- Tried to start but it only clicked
- Jump start according to the manual
- Bought a new battery
-> nice start
But:
.. Volume control, media and search on the steering wheel is not working.
.. Radio turns off with the ignition but should be on until I pull the key out.
.. Emisson check blinks 8 times but then turns off
Nothing else so far.
Please help me as we need the car tomorrow and this already ruined my Thanksgiving mood.
Any advice is welcome
Eric
  #2 (permalink)
Old 11-24-2011, 12:13 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
check your fuses
sounds like you blew some fuses when trying to jump it. make sure to check the underhood ones as well
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 11-24-2011, 03:08 PM
TCAS007's Avatar
Quote:
Originally Posted by Tylus View Post
check your fuses
Fuses look fine.
Radio illumination is down too.
  #4 (permalink)
Old 11-25-2011, 02:56 AM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
all the stuff you are listing as being messed up are controlled by the Instrument Cluster.
You said the fuses are good, but did you check the ones under the hood?
__________________
  #5 (permalink)
Old 11-26-2011, 01:24 AM
TCAS007's Avatar
They're ok too. Will go to the dealer next week.
  #6 (permalink)
Old 12-02-2011, 11:28 AM
TCAS007's Avatar
Back from Ford.
The car lost it's memory and needs to be reprogrammed. To do this they need both keys and 1 hour of time. It will cost 100.-
I was told it is nothing unusual. So I wonder why nobody could help on here
  #7 (permalink)
Old 12-03-2011, 04:11 AM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
sure, it happens all the time
I've owned 4 late model Fords (<5 yrs old) and been apart of this forum for ~7yrs. You see alot of issues, but yours is a new one to me
hope your Expy stays fixed
__________________
  #8 (permalink)
Old 12-03-2011, 05:42 AM
glruff's Avatar
glruff glruff is online now
2005 Ford Ranger
glruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputation
Quote:
Originally Posted by TCAS007 View Post
Back from Ford.
So how long did you have the battery out of your expy which caused it to be reprogramed by the dealer?
Batteries are changed all of the time and do not require the vehicle to be reprogramed. How long is the memory retained before it requires reprograming?
__________________
George, FTE Chapters Moderator - FTE GUIDELINES
05 F250 6.0 FX4, Innovative Diesel Tunes/10 Expedition EL LTD/12 Explorer LTD EB/13 Platinum F150 EB
  #9 (permalink)
Old 12-03-2011, 07:56 AM
chuck s chuck s is offline
Garage is empty, add now
chuck s is starting off with a positive reputation.
My Explorer and Expedition experience indicates a dead battery can be an every week problem due to the non-switched accessory outlets.
I've resorted to "public safety spec batteries" and Priority Start boxes on both. These cut the battery off from the vehicle when battery voltage drops too low. If I had memory loss several times a month I'd be very unhappy. Yeah, I gotta reset the clock.
-- Chuck
  #10 (permalink)
Old 12-03-2011, 03:56 PM
Johnny Law Johnny Law is offline
Johnny Law is starting off with a positive reputation.
Back from Ford.
Maybe he was talking about the $100 charge, that isn't that unusual.
  #11 (permalink)
Old 12-15-2011, 06:20 PM
TCAS007's Avatar
I went back to Ford today with l keys and fobs to have it fixed.
Well after an hour!!!! they came and said that they were wrong. Radio broken and not fixable.
Got a Kenwood now, original was too expensive and this is more up to date.
Cons: the looks but oh well
Bad luck I guess.
  #12 (permalink)
Old 12-16-2011, 11:48 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Ebay has many many of our radios for around $100. Easy to install. Takes about 10 minutes.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #13 (permalink)
Old 12-16-2011, 12:37 PM
TCAS007's Avatar
Quote:
They need the part number that fits and all except one I saw matched with mine. They look all the same though, would build in but not work.
That is what I was told at Ford at both places.
Not worth the hassle for a basic stock radio.
  #14 (permalink)
Old 12-16-2011, 12:39 PM
berry1234's Avatar
If it was pulled out of the same year Expy it will work.
__________________
  #15 (permalink)
Old 12-16-2011, 01:26 PM
kennisonxgs kennisonxgs is offline
kennisonxgs is starting off with a positive reputation.
Don't they need to be programmed for the specific vehicle as well, or does that apply only to the Nav systems?
Tags
08, 2008, 2009, battery, cluster, ddx, expedition, f250, factory, ford, instrument, kenwood, problems, reset, start, truck, woofer, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
