You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I want to change the thermostat because it seems to be taking a lot longer to warm up and temp gauge only goes up a little into operating range. The whole system was flushed and changed 30,000 miles ago by dealer but the coolant is green?? Acording to some guys on this site that is not good?? Before the snow flies I just want to change out the therm. and top off. I will completly flush and change coolant this spring, but for now I just want the truck to warm up faster when wife drives it...It is a 2001 EX with the 7.3...thanks guys.....THINK SNOW!!!!!!
Changing the thermostat is not a big deal & the green coolant is just fine if you keep the DCA right. Be a good time to get some dip strips & check it.
Drain the rad down to a level below the water pump, take the upper hose off, 3 bolts at the thermo housing. Make sure you get the correct thermostat.
__________________
2000 F250 7.3 Auto SCLB 2WD PHP Tunes AIS 4"TBEXH CCV Mod W-W
Where ever you get it, make sure they're identical in length. If you get a short stem one, your cooling system won't flow properly and will overheat!. I got Bob's 203 degree t-stat and the billet housing. Even with the new housing, I still have a slight leak at the flange, so a little permatex would be a good idea when you do your install.
The 203 t-stat is one of those debated things, some say that it leads to high oil temps, but on the flip side, it was what International designed to be run in these engines. In my case, the truck warms up way faster (old t-stat was shot) and runs at temp now. I also gained 1mpg from it running so cool all the time.
__________________
Trevor
01 F-350 CC 8ft bed SRW 7.3L a/t. 190k
PAA Member #7
I just had the same issue with warming up slow and the temp gage was only getting just above the cold mark. I researched all thermostat options and the best looking(heaviest duity)thermostat and gasket was the Ford thermostat. I thought about the 203 and was talked out of it by two of our biggest supporter companies on this site. I put the Ford 192 thermostat in yesterday and my temp gage is up a quarter of an inch from where it was before. Truck seems to have more power now with the higher temp. I'm happy with the Ford thermostat!
__________________
2000 F250 Lariat
7.3, 4R100, 4x4, CC, SB, 4"lift, 315/75/16, AIS, GTP38R, Turbonetics outlet, 4" MBRP, Swamps 200/30 Hybrids, Swamps tunes, Swamps HI V/F IDM, IH bellows, Plenum inserts, Ic boots, OCR, HPx, FRx, Hutch/Harpoon, spin on prepump filter, Bosch pump, DIY 3/8 fuel lines to heads, Autometer boost, trans, pyro, coolant, Isspro EV2 fuel press, ELC, coolant filter, BTS vb, 6.0 trans cooler, Melling LPOP, traction bars, AE and more.
Great discussion, thanks. It gets a little warm in the cab. That 16 miles is mostly at 45-55 mph, no stops. Outdoor air is about 40. I think I'll try the 203 -- not sure what it has in it now as I am the new, 3rd owner.
Let us know what you think of the 203 after you run it awhile, I'm one of the ones still undecided about it
__________________
After I get around to making the change, I will post back with the results. Maybe I'll even take a picture of the temp gauge and trip meter before and after. It may be a few weeks. Thanks everyone.
I would stick with the Ford T-stat over the NAPA one. I noticed a difference in design which made me nervous about installing it. The OEM is on the right, the NAPA is on the left. I noticed a difference in the bleed hole and the rubber o-ring that is on the Ford part and not on the NAPA one. Since my old one was still working fine, I reinstalled it. I also love the billet T-Stat housing from Dieselsite. Here's my writeup on the entire T-Stat housing swap I did:T-stat Housing Replacement
__________________ Chris
2002 F350 XLT, 7.3L CC 4x4, SRW, Autometer Ultralites, DP TUNER, BTS Trans, 6.0 tranny cooler, F650 dash, AIS w/zoodad, Warn Hubs, 4" MBRP exhaust, '08 rear end cover, Foil Delete, Heated Tow Mirrors, AIH Delete, Homemade CCV mod., Bilsteins. The Silver Bullitt PAA# 24
The 203 will not make the truck warm up quicker it will only run hotter when it does warm up. After replacing my old bad one with the 192 ford one, my truck runs plenty warm and I can't believe the power difference with the hotter running engine. Also got a 1-2 mpg gain. I would be afraid to see how high my temp gage would be with a 203.
__________________
2000 F250 Lariat
What temperature is "plenty warm"?
__________________
2000 F350 cc lariat 4wd 7.3l "You will get used to clux. He has a secret agenda of pointing out the obvious. "-kw5413
I don't know what temp I'm actually running. I'm puting in a an old temp gage I had today. I'm just going by the stock one, the needle is just below the half way point on the stock gage. Before my new thermostat it was about an eight of an inch above the c line. I will know later today what temp I'm running, I will post it.
__________________
2000 F250 Lariat
Just a question why not use the block heater if you have one? That will warm it up faster.
