'62 F350 Emergency brake boot
I am trying to locate a boot for the emergency brake and the shifter. The parts mags that I have looked in show the shifter boot for a F100-250 Only. Would these be the same for the F350. I cant find any listing for the emergency brake boot. Mine is located in the trans hump.
Before repairs...
After repairs (removed/filled holes for lift box arms....
Before repairs...
I had asked this question before but had a hard time finding it again.
https://www.ford-trucks.com/forums/1...ncy-brake.html
Either way, it looks like this may not be the correct part anyway beings mine has four holes.
Transmission is a Borg Warner T-98 4 Speed Manual Transmission. There are no holes to mount a shifter boot so I assumed that it must be installed in the trans cover and not bolted in place.
I will measure the opening and replay later.
Thanks!
Thanks!
Thanks!
Thanks!
1967-79 Full Size Truck/bronco - Transmission Manual - Borg Warner T-18
might be what you need.
Jolly Roger Joe
03-09-2013 06:18 PM
Rusty_Old_F250
35
11-14-2011 05:54 PM
bobfl
04-23-2002 05:47 PM
