Ford 460 Belt Diagram? - Ford Truck Enthusiasts Forums
Old 11-23-2011, 10:13 AM
timleonard32 timleonard32 is offline
timleonard32 is starting off with a positive reputation.
I just got a 82 F150 with the 460 in it and I need to know where I can locate a belt diagram. The problem is that I am not sure if this is the original 460 or if it is from a different year or generation completely. Help?
Old 11-23-2011, 11:41 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
460's were not factory in an 82 F150.
If it has a serpentine belt, it's from a newer application.
Old 11-23-2011, 11:54 AM
I do believe it has two seperate belts. The truck started as an f150 and by the time I got it it has a 250 clip and the 460
Old 11-23-2011, 02:04 PM
lavatan's Avatar
lavatan lavatan is offline
lavatan is gaining momentum as a positive member of FTE.lavatan is gaining momentum as a positive member of FTE.
If it's the standard V-belt there should be 2 of them. When I redid my engine I just took a cord and wound it around the pulleys for each belt and measured the cord to get the general idea of length. As far as routing (I don't have A/C) the front pulley on the crank goes to the right as your looking at the engine to go around the power steering pump and the other back pulley goes to the left for the alternator. I don't have that air pump BS anymore. Took all that smog control stuff out when I rebuilt the engine. I suppose I should just get static pulleys but it seems to work for now.
Old 11-23-2011, 08:32 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
This might (or might not) help - from a 460 in a 1980/89 van with dealer-added AC:
Old 11-23-2011, 11:25 PM
xirxious xirxious is offline
xirxious is starting off with a positive reputation.
Someone cut/cobbled up my 86. If I can find the brackets, I want to redo it all like an early 70's and scrap whats left of the emissions.
Old 11-24-2011, 10:13 AM
I had one belt still on the water pump/crank shaft pulley. Is there suppose to be on belt or two seperate?
Old 11-24-2011, 10:40 AM
I just went out and looked and it is a 4 pulley system without a/c
belt diagram Fitzgerald_welding 1987 - 1996 F150 & Larger F-Series Trucks 11 03-15-2016 04:19 PM
V belt diagram or pictures? DonJuanDiego 1968-2013 Full Size Vans 0 06-03-2014 09:08 PM
Alternator belt length Sooper Camper 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-07-2013 10:32 PM
Belt Diagram mollikate 1999 - 2003 7.3L Power Stroke Diesel 2 07-14-2007 08:20 AM
Serpentine belt diagram sangin67 Aerostar 6 05-18-2006 01:40 PM
Tags
1974, 1978, 1985, 460, 58, 75, 86, belt, belts, big, block, diagram, diagrams, ford, routing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
