HPX pros and cons
Old 11-23-2011, 08:24 AM
cps's Avatar
cps
cps is offline
HPX pros and cons
Is there any pros and cons between the hard line Hpx and soft line for those of you that have one or the other? Trying to make a decision on which. Roy
Old 11-23-2011, 08:29 AM
cj45lc's Avatar
cj45lc
cj45lc is offline
I believe if I was gonna put one on I'd get the hard line
I was told it's just another potential oil leak
Old 11-23-2011, 08:31 AM
bulla's Avatar
bulla
bulla is offline
The steel line would last longer! That would be about it. Unless your diy the steel one would be a lil bit harder to get the bends just right. But if your buying one the steel one clay sells fits great! I think the only disadvantage to the crossover itself is you have to remove it pull the turbo.
Old 11-23-2011, 08:37 AM
mueckster's Avatar
mueckster
mueckster is offline
I've had both. The soft line started weeping at the crimp after a few years. So, I now have the KCM SS hard line HPX and I don't have to remove it to do a turbo R&R. It dips down in the middle and still gives just enough clearance to get the turbo past it.
Old 11-23-2011, 08:52 AM
cps's Avatar
cps
cps is offline
Thanks, just what i wanted to hear! Also who is KCM?
Old 11-23-2011, 09:32 AM
kccatpower's Avatar
kccatpower
kccatpower is offline
dont forget about PMS, i installed the hardline from clay and it fit great, this was also a good reason and time to install the plenum inserts, new boots and clamps.
Old 11-23-2011, 09:39 AM
woodnthings's Avatar
woodnthings
woodnthings is offline
KCM Diesel Performance, they just have a version of the hard line HPx.
KCM HPx Install Instructions
Clay at Riffraff has a version of the HPx that is hard to beat!
Riffraff HPx
I recommend the hard line version over a flex line. Just as simple to install and leaves no chance of it moving around with vibration. Also takes less space up, in an already tight area.
Old 11-23-2011, 07:09 PM
cps's Avatar
cps
cps is offline
Riffraff HPx
I will go with the hard line but my concern was being able to remove the turbo or anything else in there without removing the HPX. i thought with a soft line i could bend it if needed to get any clearance that i might need. Roy
Old 11-23-2011, 07:16 PM
woodnthings
If you have any issues, it takes all of a few minutes to remove the HPx to get it out of the way.
GCLL
6.7L Power Stroke Diesel
12-03-2016 10:22 PM
Krjeep
11-26-2016 01:33 PM
Dave Koehler
04-08-2016 07:54 AM
F-250 Super Duty
09-02-2010 09:16 PM
165
02-16-2009 08:52 PM
Quick Reply: HPX pros and cons
