my ZF5 install - Page 3 - Ford Truck Enthusiasts Forums
my ZF5 install
  #31
Old 11-25-2011, 07:03 PM
91dirtydiesel's Avatar
91dirtydiesel 91dirtydiesel is offline
91dirtydiesel is gaining momentum as a positive member of FTE.
So looks like I've hit a snag, is there an adapter on the crank for the e4od??? Zf flywheel doesn't fit and looking at my spare motor the crank looks a lot shorter. See pics
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=b74400b0.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/b74400b0.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=72338904.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/72338904.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
  #32
Old 11-25-2011, 08:53 PM
got it
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=a2df3570.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/a2df3570.jpg" border="0" alt="Photobucket"></a>
  #33
bad a$$ roth bad a$$ roth is offline
bad a$$ roth is starting off with a positive reputation.
thats a spacer for the flexplate and u inadvertantly answered my question if i needed to use it with the flywheel. im in the middle of the same swap. tap it with a hammer and it should pop right off. i found it when i put my new flex plate in. over torqed the flexplate mounting bolts and snapped on inside it. started drilling it out and the bit slipped and pulled it right off...needless to say it scared the **** outta me bcause i thought the whole crankshaft was gonna do it. ivelearned alot over the past four months but try that and ask others. i never do anything till four people say the same thing and others agree............nevermind.
  #34
Old 11-25-2011, 09:17 PM
today got the e4od and tcase out, looked at my clutch/flywheel and compared it to my 93s old set up....looks like i have a LUK SMF got all that installed, (flywheel torque 75 ? pressure plate 25 ?) and got the new radiator in.
lil red sled being lazy not wanting to reach his hand up.....
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=795a2563.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/795a2563.jpg" border="0" alt="Photobucket"></a>
skechy
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=70856f21.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/70856f21.jpg" border="0" alt="Photobucket"></a>
worked
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=cb5262e0.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/cb5262e0.jpg" border="0" alt="Photobucket"></a>
for sale
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=149b064d.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/149b064d.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=dd36e749.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/dd36e749.jpg" border="0" alt="Photobucket"></a>
luk smf
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=730bc40b.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/730bc40b.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=9858ecd8.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/9858ecd8.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=19dbd648.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/19dbd648.jpg" border="0" alt="Photobucket"></a>
old dmf
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=f90214d8.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/f90214d8.jpg" border="0" alt="Photobucket"></a>
clutch
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=5cc4eee8.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/5cc4eee8.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=831e17c6.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/831e17c6.jpg" border="0" alt="Photobucket"></a>
  #35
Old 11-25-2011, 09:21 PM
crash1's Avatar
crash1 crash1 is offline
crash1 is gaining momentum as a positive member of FTE.crash1 is gaining momentum as a positive member of FTE.
lookin good the 5 speed is well worth the trouble.
  #36
Old 11-25-2011, 09:30 PM
tecgod13 tecgod13 is online now
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by farmert View Post
Look threw this thread http://www.ford-trucks.com/forums/94...-complete.html . Can't say that I like his choice of titles, but it has some good pics, of the DMF, and how to tell when they are done for.
Well he's right about that being a way to see if they are worn out, but completely clueless about why its shot and how it works. Some movement is normal though.
The clutch like material he found is just that, an overtorque prevention slip clutch. Its tensioned by belleville springs (washer like things). It is normally locked and has nothing to do with the flywheel turning a little back and forth. It will slip if overloaded to "protect" the flywheel or transmission. Supposedly it can over heat in certain situations (like when doing tight maneuvers with a heavy trailer). I'm not sure exactly how much its designed to slip, but after doing it a bit, it will wear out and slip when your truck is unloaded and going up a steep hill (because mine did and it sucked!!)
The plastic things that hold the springs in place will frequently wear down, or crack and break (like in the pictures). I had at least one that was completely broken off and one of the springs had been rattling around some, thats bad too. My guess is that the springs will fatigue over time and become a little shorter and that with wear on the plastic parts causes the excessive movement.
Also, a DMF can be taken apart with drilling out the rivets. It takes a couple screwdrivers to pry out the springs. Putting it back together like that is a pain in the ***, but doable.
  #37
Old 11-26-2011, 08:27 AM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
Quote:
Originally Posted by 91dirtydiesel View Post
Hope not, pulled it from the zf truck myself ? If it is the auto one then it was working fine ???
The one in you bed? Maybe I'm just seeing things, but a ZF crossmember is 3 pieces and looks rather different.
  #38
Old 11-26-2011, 05:13 PM
U might be right snap....pics coming. Drilling was required for this one but defiantly not the same as the e4od one
  #39
Old 11-26-2011, 10:15 PM
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=a64e4821.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/a64e4821.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=b9a580d8.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/b9a580d8.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=df5e970c.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/df5e970c.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=ae5fac63.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/ae5fac63.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
  #40
Old 11-27-2011, 12:25 AM
wiring
left is the e4od, right is the zf5
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=bb9b9b97.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/bb9b9b97.jpg" border="0" alt="Photobucket"></a>
transfer case to tranny
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=c2d0b7a4.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/c2d0b7a4.jpg" border="0" alt="Photobucket"></a>
plug from the zf5 to main harness
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=65842066.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/65842066.jpg" border="0" alt="Photobucket"></a>
t case speedo
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=05d739a0.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/05d739a0.jpg" border="0" alt="Photobucket"></a>
by the 4x4 linkage
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=9dc48c2d.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/9dc48c2d.jpg" border="0" alt="Photobucket"></a>
on the transmission
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=7ffdfcd2.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/7ffdfcd2.jpg" border="0" alt="Photobucket"></a>
  #41
Old 11-27-2011, 01:00 AM
crash1's Avatar
thats one thing i like that ford did well on is my 90-91 harnes for the trany pluged right into my 97.
  #42
Old 11-27-2011, 01:59 PM
Not the same as mine but I guess they change in the years. In fact I like your design better, looks easier to install.
  #43
Old 11-27-2011, 03:09 PM
What's this plug?
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=5df80439.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/5df80439.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
  #44
Old 11-27-2011, 04:32 PM
i agree with snapon...but mines 2wd. camt wait to c it done. keep up the good work.
  #45
Old 11-27-2011, 05:46 PM
What's this plug?
Clutch interlock switch. It tells the truck when the clutch is pushed in. Useful for starting (so you don't run something over by accident) it takes the place of the neutral switch from an automatic transmission. Its also used by the cruise control to know when you've hit the clutch (and thus to stop the cruise from giving it fuel).
While not necessary if you don't have cruise control, its a good safety feature when starting.
IDI dragster: Silver Bullet 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 307 09-13-2013 06:40 PM
turbo experts 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 03-02-2012 11:14 AM
new seats! 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 09-26-2011 09:22 PM
ats turbo preview 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 60 07-19-2011 12:37 AM
old injectors with rust and carbon 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 42 02-18-2011 12:08 AM
Tags
1992, 8box, cab, caps, click, extended, f250, fiesta, ford, idi, instal, luk, oil, smf, stuck, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
