Factory skid plates? - Ford Truck Enthusiasts Forums
Old 11-22-2011, 06:49 PM
REAPER4206969 REAPER4206969 is offline
REAPER4206969 is starting off with a positive reputation.
Question Factory skid plates?
Other than the transfer case plate, were there any other skid plates offered on the F-Series of this vintage? I'm going to the wrecking yard in search of the TC plate, and I want to get any others as well. My truck is a '90 F-150 SC/SB 4X4 with single tank, BTW.
Old 11-22-2011, 09:18 PM
Will Chiello Will Chiello is offline
Will Chiello is starting off with a positive reputation.
My 92 has them for the gas tanks
Old 11-22-2011, 09:24 PM
On the rear one as well?
Old 11-22-2011, 09:52 PM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
Mine's got one on the front tank only; the rear doesn't.
Old 11-22-2011, 09:57 PM
Thank you for that info.
I just went and looked under my truck, and I can't see how a rear tank skid would do anything as the tank is mounted way up under the bed and fully covered by the spare tire assembly.
Old 11-23-2011, 10:07 PM
Anyone else?
Old 11-24-2011, 05:42 AM
Cheggie's Avatar
Cheggie Cheggie is offline
Cheggie is starting off with a positive reputation.
All I've ever seen is the one covering the t-case, and the one on the forward fuel tank.
Old 11-24-2011, 06:45 PM
Thank you, that was very helpful.
I'll be going tomorrow or the next day, and will report my findings.
Old 11-24-2011, 07:32 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
The Off road PKG has t-case, front and rear fuel tank skid plates
Old 11-24-2011, 08:51 PM
Does anyone have a pic of the rear tank plate? I don't understand how it would do anything considering the tanks location.
Old 11-24-2011, 09:06 PM
What is to understand? It covers the bottom of the fuel tank(just like the front one). That way if you drive over something or back over something, it will hit the skid plate and NOT the tank
Old 11-24-2011, 09:43 PM
Maybe it's just mine, but my rear tank is completely covered by the spare tire assembly.
There is no way anything could hit it.
Old 11-24-2011, 09:58 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
FYI.. the transfer case skidplate hangs WAY low on these trucks, I took mine off since I never go offroad and because I thought the truck looked stupid with this big chunk of steel hanging down underneath. The fuel tank skid plate fits much tighter but it also collects a lot of dirt, I bet I dumped a couple pounds of sand out of it when I dropped it.
Old 11-24-2011, 10:37 PM
It is for those who do not have a spare tire,
Old 11-24-2011, 11:49 PM
GoinBoarding GoinBoarding is offline
GoinBoarding is gaining momentum as a positive member of FTE.
The spare tire carrier sucks (cut mine off years ago after the first time I had the pleasure of breaking it to remove my spare), so my spare stays in the bed, locked down to a chain welded to a bed bolt. I would have a hard time hitting my rear tank on anything with how low the receiver hitch sits, but the plate there wouldn't hurt to have. As far as the TC skid plate sitting so low and looking stupid, it has to sit low because the TC sits low. And a TC looks pretty stupid when its split open But as Conanski said, if you're not wheeling it doesn't have much use and does look a little funny.
Need Help skid plates # rj242 6.7L Power Stroke Diesel 5 09-18-2015 09:15 AM
Front skid plate.... mjmcd 2015+ F150 0 07-22-2015 04:49 PM
Factory Skid Plate Pics? RISUPERCREWMAN 2004 - 2008 F150 0 01-17-2014 08:27 PM
Fuel tank skid plate Fordby4 1973 - 1979 F-100 & Larger F-Series Trucks 9 06-26-2010 08:05 PM
E350 skid plates? bill11012 1968-2013 Full Size Vans 3 03-04-2010 08:56 PM
Tags
1979, 1996, 2003, f150, f250, factory, ford, install, plate, plates, platw, side, skid, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
