dose anyone know if i can put a new say 97 to 99 5speed transmission in my 92 as my mazda transmisson has no 1 or 2ed gear and i cant find a mazda anywhere around here
Yes, and no...
Yes-The transmissions are the same...
No-The bellhousings/bolt patterns are different....
ANY small block ford (300, 302, 351w) will bolt right up....Only issues will be cross member/driveline....
Are you looking for the Mazda 5 spd? I'm swapping out the mazda in my truck 1989 f-250 light duty 5.0 5spd would sell as a pkg, is leaking a little at rear seal. has 78k on, looking for ZF for the 460 I'm installing. Located SW Minnesota.call if interested, truck still running, just putting together the equipment needed to do install.five zero seven, eight 2 eight, sixty, eight, sixty
