73-77 f100 grille and plastic inserts
Category: Accessories
Price: $140
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude
Item Condition: NC
aluminum grill has slight dent in it can send pics apon request
I'm intereted in your grille. I would like to see some pictures. I have a 78-79 Grille with silver and black inserts and both round and square headlights if you'd like a trade instead
the grille on the truck has a slight bend as you can see in the pics on the top just to the right of the center piece and i have a set of the inserts for the square headlights but i am interested in the round ones you have
okay, what part of NC are you in? Would I have to change my headlight mounts to fit your grille? With your 73-77 i'd probably have to keep the round headlights. I'm not sure. Will that black paint come off of the other grille?
as long as yours has the round headlight i wouldnt think so i have square and round headlight mounts i can check and see if they are the same and yes with a 73-77 yes the round headlights but the headlight beauty rings are built in to the grille inserts and the paint should come off ive been told of several things to try but never have and im in statesville about 30 miles north of charlotte where u comming from ?
ok. I'm about an hour north of Bristol Tenn. One of my headlight beauty rings had broke on my truck. I doubt I'd be able to make the trip right now with my truck being at the body shop and us only having one vehicle.
are you passing on it then or im sure i can hold the grille for you its probally not goin anywhere but as im sure u have read bama is interested in the inserts also wat do you want for the round headlight inserts for the 78-79
kdmcinnes
16
11-03-2009 12:16 AM
