Oil bath vs. paper element air filter
I've read many times where the oil bath filters are actually more efficient than a paper filter, but they are messier and more difficult to service than just swapping out a dirty paper element. And paper obviously works plenty well enough as that is all that the OEM's have used for decades. I really don't think you can go wrong either way. I've not attempted it yet, but some guys are converting their oil bath housings to use a paper filter to combine ease of maintenance with a stock look.
Haha, that's one way to make a mess! I don't think power turning will be an issue, but there are a lot of hills around here, so that might have the same effect... I'd like to keep the look (and functionality) of an oil bath, but, I might have to "dry it out" and convert it to a regular paper filter.
Paper filters were developed for folks who do not like to work with dirty stuff. They worked well for many years and many applications. They're still working on my tractors and my '56 F350. Many of them still doing the job efficiently.
Paper filters gives the manufacturer and aftermarket folks a way to sell a product where a cleaning and a small amount of oil makes the oil bath efficient and back on the job.
So far as service on the oil bath. I pour the oil into a clean container, wash the tub, pour the top of the oil from the container and top off with fresh oil. Since the oil never gets into the engine, any dirt remaining in the oil does no harm. You're just getting the sludge out of the bottom of the filter.
my 54 M-H ford 4X4 has been playing on hills that let me see only sky in front and all the crap in the box slid to the tail gate..not sure what 25% grade is but I know I couldn't walk up the hill I drove the truck up ..and the oil bath did not slop over it works fine and I am not about to change it ,so the slop is not a problem and cleaning is a twice a year with oil and filter changes ..so my vote is stay with the bath
The conversion is simple to do, and if done right, you'll never tell from the outside. Here's a how-to thread I made a while back. For the few dollars a paper filter costs, you'll spend at least that much or more on solvent and rags every time you change the oil and clean the unit. That's my 2c.
https://www.ford-trucks.com/forums/1...r-cleaner.html
As far as the oil bath filters slopping over goes, the indicated fill level is with the engine off. When the engine is running, vacuum pulls the oil up into the filter element and coats it. The dirt sticks to the oil and is carried back down to the reservoir when the oil drains back when the engine cuts off. You'd probably have to park the truck on it's bumper for an extended time to spill any!
