Fuel pressure rail code and stalling...V10 - Ford Truck Enthusiasts Forums
Old 11-22-2011, 12:19 PM
windyhill's Avatar
windyhill windyhill is offline
windyhill is starting off with a positive reputation.
Hello all, I have a 06 Van with a v10. recently it's started to stall, sometimes at idle or starting out or when driving. A little history. My check engine light has been on for about 2 years now. My reader shows a, P0191 Fuel rail pressure sensor Code. I had the pressure sensor replaced but it did nothing the engine light was back on in a few days. Since then it has run fine with no problems at all so I left it alone. That was until lat week or so, then it started stalling. I hooked the reader up yesterday and it was showing an open fuel injector circuit on cyl. 1 code. So I replaced the #1 fuel injector. and reset the computer. After a testdrive it's showing the P0191 code again and still stalling. I did try to get a pressure gauge for the fuel system but it wont screw onto the port so I don't know what my pressure is. So anyone have any ideas? I would like to solve this, so my wife doesn't Wreck the van when it stalls then next time. A 7000K Quigley 4x4 van is a lot to handle when you can't steer and the power brakes don't work!
Old 11-22-2011, 02:43 PM
windyhill's Avatar
I tried to find the IAC but the van V10 is diff then the F-350 and I can't find it. The engine will idle at about 580 RPMs according to my Innova meter, if I rev it up to 2K or so and then let it off it falls down to 220 RPMs or just stalls out.
Old 11-22-2011, 05:01 PM
3000 FPS's Avatar
3000 FPS 3000 FPS is offline
3000 FPS is gaining momentum as a positive member of FTE.
I believe I would try and find a gauge that you can hook up so that the fuel pressure can be read. Until then you are just guessing as to what is going on with the fuel pump.
Old 11-22-2011, 06:08 PM
Mr-Pipeline's Avatar
Mr-Pipeline Mr-Pipeline is offline
Mr-Pipeline has a good reputation on FTE.Mr-Pipeline has a good reputation on FTE.
I believe you have a 2V V10 and I'll assume you have the same fuel rail as my 2000. I used the Autometer #3280 fuel rail adapter to install my sensor. It will allow you to install a 1/8 NPT gauge. You can find the same adapters for less if you look around. Hope this helps out!
Project Sandy - Jaime's Project thread Jaime74656 1987 - 1996 F150 & Larger F-Series Trucks 268 09-11-2015 07:01 PM
HELP! Truck Stalled, Won't Start, & Have OBD Codes flare-f150 1997 - 2003 F150 1 07-20-2015 06:42 PM
how to test fpdm? jamesdart 2004 - 2008 F150 0 09-16-2011 11:28 AM
Gettin ready to throw in the towel HELP 5Rangers 1987 - 1996 F150 & Larger F-Series Trucks 4 07-25-2011 09:42 PM
Wiring for door speakers Ford Escape olof Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 10-11-2005 06:35 AM
Tags
2008, 54, code, engine, f350, ford, fuel, po191, pressue, pressure, rail, sensor, stalling, v10, wot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
