What do you think
What do you think
Hi all i have a 1990 f150 4x4 when i turn the key on to the acc position my truck starts up and the starter keeps going until i shut the key off (instead of the start position) i have ordered a new ignition barrel being australia it takes a while to get parts do you think this will fix the problem
Between that, and the stuck starter solenoid (The one on the starter)....I think you've narrowed your issue down....
Btw...I'll add this...Try havin someone crank the truck over, and you taking a small hammer, and pecking lightly on the starter housing and the solenoid on top...if its simply stuck, it should solve the issue....No guarentee's on how long it'll be till it sticks again though....
Again, LIGHT pecking is the key..no need for a 9lb sledgehammer...
the ignition switch (not the barrel) has some adjustment to it, also the rod that goes from the barrel to the switch likes to bend,
and you might want to make sure that its the right wire thats going to the solenoid. if you got the truck like this it may be possible that somebody hooked an ign+ wire to the solenoid instead of the switched power.
also for testing with the starter, you could disconnect the cable from the solenoid to the starter and hook up a test light instead so that your not trying to work on a truck that is running and cranking at the same time!
thanks for the replys i have just been out the shed playing with the truck and this is what i have found
i have disconnected the wire for thew starter of the solinoid / relay on the fender of the treuck mine is on the right hand side being australian now when i have the key in the on position i can touch the wire to the relay and the starter will engage and when i remove the wire the starter will disengage so dose that mean that the problem must be in the ignition of the truck
i am really greatfull for all your help and the welcoming to the site
Symptoms warrant giving its adjustment a good going over and if needed checked with a tester see what the deal is. Is it the switch or something in the harness narrow it down.
thanks for your help everyone what i have done now is replaced the ignition barrell with and brand new one i have replaced the ignition swith the starter and the relay located in the engine bay
anyone have any more ideas that i could try
or does anyone wanna buy a ute
thanks
thanks
Do you have the exact same problem? You turn the key back to the "acc" position the starter is engaged and the motor starts? (If so as you probably know that shouldn't happen!)
Has the new ignition been adjusted and checked for proper operation IE; when you turn the key to "start" the ignition switch is pushed (working from memory here, it is pushed ain't it?) to the "start" position and when the key is released it self returns to the "run" position?
If so exactly what happens or doesn't happen when doing so?
What has power and what doesn't in the start and run positions?
Was this truck "new to you" by chance and in this condition when you got it? or worked fine/normal for you been driving it condition came on sudden like?
Yep i have the exact same problem the truck came to me with this problem one of very many i will never buy a mechanics car again
The issue i have is i have checked the for correct operation and it all seems to be working fine at the back of the igniton setup on the steering coloum you have a series of wires when the key is in the off position none of the wires have power when the key is in the Acc position all the wires have power except fort the green on wich i have traced back threw the many stages and is the starter wire
now when i turn the key to the on position all the wires have power including the green one (which shouldn't have power)
then again when it is in the start position all the wires have power
i hope this is enough information anything please ask and i will try to answer best i can
as far as being a mechanic goes im a pretty good miner
i have taken it to the auto electrical shop but after three tradesman looking at it and 2000 dollars im in the same position as before
So let me get this straight....In teh OFF position....You can turn the key BACKWARDS (ACC mode) and the truck starts? Hmmmm.....
Now, If you turn it FORWARDS (ON) The fuel pump primes, etc....? And then to press the key further forwards (Start position) the truck starts...Correct?
Now, my question is, does the fuel pump prime, in the ACC position? If so, it sound like someone has crossed a wire ove from the Start position, to the ACC position...
Also...Side note....
When you turn the key to ACC position...Does the starter engage, and keep cranking, even when the engine starts?
