TPMS system situation... 2011 SC, 6.7...
Bought another F-250...since the wife does not like us to drive the the CC in the winter. So that opened the door to get another. So, the used SC came with 22" custom wheels (nice ones)....I changed the CC 20" customer wheel and put them on the SC and vice versa on the 22" wheels. The Ford dealership owner (who's SC I bought) gave me another set of OEM 18" wheels and tires which I sold and bought a set of 20" OEM wheels and tires....that came with sensors in them. Now the problem starts. After changing the 20" mags out with the 20" OEM's for the winter.... The TPMS light comes on at the dash. So, I get the book out and read about training the wheels and the process to take. After 3 hours and no luck on training the wheels I take it to the dealer. And they could not train the wheels ...with a little gadget that was the size of a key chain remote starter thing. They asked to see if I could find out what year the OEM 20" Ford wheels were from. I found that out and they were off a 2009 F-250. Returned tot he dealer and they tracked down that after JANUARY 2011 Ford changed the sensors and module portion of the computer. So now I am trying to find the part number of the newer wheel sensors and ANY information that any of you might be able to add.
Bottom line seems to be any wheel sensors prior to JAN 2011 will work on older trucks but not on newer trucks.
Dealer is correct except the date. MY08 and MY09 use banded TPMS sensors while MY10+ uses snap-in stem mounted sensors. The sensors are not interchangeable. You will want the stem mounted sensors which are Ford P/N: 9L3Z-1A189-A (Motorcraft P/N: TPMS-12) or Schrader P/N: 20315. Ford sources the stem mounted sensors from Schrader.
Thank you, Thank you....that is the information I am looking for. I know it will help others.
JB
The reset tool is Ford P/N: 8C2Z-1A203-A (Motorcraft P/N: TPMS-19). MSRP $53.93 which is about double what it used to be...
Note that you only need to reset/train the sensors if you are rotating the tires AND the fronts and rears require a different tire pressure, such as with 17" and 18" tires OR in a case such as yours where you will be adding new sensors.
Reset tool is not need for MY10+. You can just follow the reset procedure in your owners manual. Alternatively you can follow the MY08 - MY09 reset procedure which does require the reset tool. I prefer the older procedure with the reset tool as you do not need to mess around with letting air out of the tires...
WELL......THE SAGA COUNTINUES.......
Bought 4 new sensors (9L3Z-1A189-A) for the wheels. Needed some maintenance performed on the SC, so off to the dealer I went. They did the maintenance and pulled the wheels/tires and removed the strap on older sensors and installed the new sensors. Then the sensors would not train to the module. Tried 3 different transmitters that were at the garage, also tried the manual setup...no good. When I had ordered the TPMS sensors, I also ordered a sensor tool (TPMS19)(I forgot to take it with me to the dealers). So when i returned home, I tried to train the sensors tot he module......no go. So my dilemma continues with the light on at the dash. I have driven the truck far enough (100 miles today) for the system to (so call) reset it's self. I did email the dealer to see if they had a module we could try to eliminate another piece of the puzzle. And then the only thing left is the batteries are bad or weak in the new sensors. Or the wheels an tires are not for the newer Fords ...
Here is what PowerStrock HD asked me to do.......and it worked.
Enter training mode...
1. Make sure all doors are open.
2. Make sure key is OFF.
3. Press and release brake pedal.
4. Cycle key from OFF to RUN 3 times, ending in RUN.
5. Press and release brake pedal.
6. Turn key to OFF.
7. Cycle key from OFF to RUN 3 times, ending in RUN.
Did training mode activate? If so, proceed to LF tire with TPMS19 tool. Place tool on side wall at the valve stem with the arrow on the tool pointing towards the stem. Press button. It could take up to 10 seconds to recognize and tool should not be moved. Does it train?
If you do not have a TPMS19 tool...I would suggest running the tire pressure up to about 68-70 psi.Once in training mode...start with the LF tire and let some air out......until horn honks and then finish rotation and then do a final air pressure setting. Mine are 65 psi all around as per the computer setting.
Let us know how you make out.
Unfortunately, no and sorry about the confusion. MY08 and MY09 have to use the banded sensors. MY10 + have to use the stem mounted sensors. They are not interchangeable and the stem mounted sensors are not backwards compatible.
