Electronic ignition for FE
Old 11-21-2011, 04:38 PM
Justins68ford's Avatar
Justins68ford
Justins68ford is offline
Summit Racing SUM-850309 - Summit Racing Street & Strip® Ready-to-Run Billet Distributors - Overview - SummitRacing.com
MSD Ignition 8203 - MSD Blaster 2 Ignition Coils - Overview - SummitRacing.com
Hello, I bought the above distributor and igntion coil for my 352, I am now at the point of my rebuild where I am installing the distributor and it dawned on me that I have no clue what I am doing when it comes to ignition systems, I think I still need to purchase an ignition box any recommendations? Also any good wiring diagrams out there for electronic ignitions I know there are ballast resistors and stuff involved but I am clueless, If it is not in my "rebuilding FE's" book then I am lost. I am still probably a month away from installing the engine back in but it would be nice to know what I am doing when the time comes. Thank-you.
Old 11-21-2011, 07:10 PM
1912barry's Avatar
1912barry
1912barry is offline
<TABLE class=overvw><TBODY><TR><TD class=overvw-labels>Compatible</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>No</TD></TR><TR><TD class=overvw-labels>Trigger Style</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>Magnetic</TD></TR><TR><TD class=overvw-labels>Advance Type</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>Vacuum and mechanical</TD></TR><TR><TD class=overvw-labels>Cap Style</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>Male/HEI</TD></TR><TR><TD class=overvw-labels>Mechanical Tach Drive</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>No</TD></TR><TR><TD class=overvw-labels>Slip Collar</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>No</TD></TR><TR><TD class=overvw-labels>Gear Material</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>Steel</TD></TR><TR><TD class=overvw-labels>Ignition Box Required</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>No</TD></TR><TR><TD class=overvw-labels>Distributor Rotor Rotation</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>Counterclockwise</TD></TR><TR><TD class=overvw-labels>Distributor Cap Color</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>Black</TD></TR><TR><TD class=overvw-labels>Housing Material</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>Billet aluminum</TD></TR><TR><TD class=overvw-labels>Housing Finish</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>Natural</TD></TR><TR><TD class=overvw-labels>Quantity</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>Sold individually.</TD></TR><TR><TD class=overvw-labels>Notes</TD><TD class=overvw-midmargin></TD><TD class=overvw-data>Use coil with a 1.400 Ohms primary resistance or a low resistance coil and included ballast resistor. Distributor drive gear is melonized and compatible with flat tappet or hydraulic roller cams. 0.500 in. distributor shaft.</TD></TR></TBODY></TABLE>
It says that no box is required and the coil you ordered allready has an included ballast resistor, so you should be able to just follow the directions on the new dizzy for wiring. Your stock wiring should have a resistor wire feeding the stock coil and you could use the stock coil with this new dizzy if needed.
Old 11-22-2011, 08:54 AM
Justins68ford
Thank you I guess what I was wondering was SHOULD I just go ahead and replace the ignition box, do they go bad often? is it something that may strand me somewhere?
Old 11-22-2011, 11:06 AM
1912barry's Avatar
1912barry
Your new dizzy should be a stand alone system, no box needed. I had a Mallory unilite many years ago and it just went inplace of the points dizzy. It was real simple to hook up. Just wire it the way the instructions say to and all will be fine.
braol
11-29-2018 05:57 PM
F-250 restorer
04-08-2017 06:03 PM
Austin Hartman
08-02-2016 08:37 AM
Cbad285
18
03-07-2016 11:44 PM
rbtom
13
02-23-2015 07:50 AM
Quick Reply: Electronic ignition for FE
