NAPA Kool SCA?
The stuff I have is just an additive to the coolant you put in the system. You can but it by the pint or by the half gallon. The jug says that you should add one pint (16 oz.) for every 4 gallons of capacity in your cooling system as an initial charge and then that a maintenance dose of 4 oz. or so is suggested after that every 10,000 to 15,000 miles. I added about half the 64 oz. jug to the system as my initial charge. I have the test strips to test the levels, so I will run it a couple days to be sure everything is mixed thoroughly and then test it to see how things look. I can just use the strips to test the coolant after that and keep an eye on t he levels.
The next thing on my list is a coolant filter.
What did you go with for a coolant filter setup? I've looked at the dieselsite setup, butu it seems a bit pricy to me for what you get. I'm thinking of just building my own with parts I can pick up locally (NAPA again). You can also get the coolant filters from NAPA pre-charged with this additive.
That I can't say. I don't know how this stuff would mix with say the Motorcraft stuff. I guess you could always switch coolant the next time and then go with whichever product matches the coolant you put in, or for that matter, put in straight coolant with no additive in it and then add whatever you want...
I had the engine out of the truck, so I lost all the coolant in the radiator when I drained everything. Then I pulled the block plugs and put in brass drain valves for future use. There may have been a little coolant left trapped in the block and heater core, but I think I put 6 to 7 gallons of coolant/distilled water back in it so there wasn't much left.
#28
i was just thinking. i think i have a small leak at the water pump. should i can the pump at the same time i drain the coolant or should i run the old water pump for awhile with the new coolant and then change the pump a few weeks after. just in case there crap running thru the system. what are your thoughts
#29
#30
Received 3,090 Likes
on
i agree. when i change water pumps i flush the system first before removing the old pump, then drain as much of the water as i can, and refill with new after putting the water pump in
