6.0 powerstroke no start - Ford Truck Enthusiasts Forums
Old 11-21-2011, 12:59 PM
motoX45 motoX45 is offline
motoX45 is starting off with a positive reputation.
working on a 6.0 powerstroke at work(cat dealer) its one of our service trucks. replaced oil cooler, egr cooler and egr valve. truck was hard to start right after repairs. started and idled good. when first taking it for a ride, the engine and turbo spooled up as it should. but it felt like the truck was being held back. back to shop n check a few things. again idled and reved up fine. took it for another ride, truck took off like it should. got up to about 60mph at WOT, let off and the truck shut up. now its a crank/no start. i have about 580psi to the icp at crank. swapped ficm with a running truck with no luck. any ideas?
Old 11-21-2011, 04:28 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Power Stroke Diesel forum.
Old 11-21-2011, 05:23 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is online now
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Here's a good checklist for a no-start. You can speed read thought the first part but always worth going over and it gets to the "meat and taters" pretty quick:
http://www.ford-trucks.com/forums/87...condition.html
Old 11-21-2011, 07:28 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
remove the ipr valve check the screen if damaged repalce it.
Old 11-22-2011, 05:43 AM
hott-rodd hott-rodd is offline
hott-rodd is starting off with a positive reputation.
Quote:
cheezit saved me with this info a couple years ago , when i had the same problem.
Old 11-23-2011, 11:26 AM
oook so i rechecked it myself with my scanner from home and my icp is only at 65psi. sooo where does that lead me?
Old 11-23-2011, 11:44 AM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
IPR still it sounds like it stuck and isn't holding the oil pressure.
Old 11-28-2011, 10:21 AM
the screen is in the ipr valve? im not gonna bother taking the valve apart company will just buy a new one just want to make sure i replace everything while i have it apart. any other info? thanks!!
Old 11-28-2011, 10:37 AM
brickie's Avatar
The screen is on the end of the IPR,if it has holes in it replace the IPR.
ahh nevermind stupid question thanks guys!
Old 11-28-2011, 10:43 AM
recommend replacing anything else while i have it apart? companys paying for parts and id rather not have to take it back apart haha. the screen on the ipr valve was ripped but i thought i remembered seeing something about a snap to connect fitting that it prone to fail in the HPOP?
Old 11-28-2011, 10:55 AM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
man 580 ICP is close
X3 on the IPR very common after this work
Old 11-28-2011, 11:24 AM
yeah 580icp is what i was told by our shops "truck mechanic" i rechecked it with my scanner and came up with 65icp...pulled the ipr and the screens got a hole. just wondering if anyone suggests replacing anything else while i have the turbo out. just replaced EGR valve and cooler, oil cooler and all neccesary gaskets and orings. now ordering up a IPR valve.. anything else?
Old 12-05-2011, 03:19 PM
new ipr, hpop and fitting and the truck runs like a dream. thanks for the help!!
6.0 problems need help alangray 6.0L Power Stroke Diesel 5 10-17-2016 12:05 AM
truck dies with low icp pressure after bulletproofing TheBlueMule 6.0L Power Stroke Diesel 35 07-11-2015 03:39 PM
6.0 hot start issues Lawrence83 6.0L Power Stroke Diesel 5 09-16-2014 10:26 AM
2005 powerstroke wont start need help please clay 6.0L Power Stroke Diesel 13 03-21-2012 11:02 AM
EGR system...Check this out. 2006powerstroke90 6.0L Power Stroke Diesel 22 09-27-2011 07:52 PM
Tags
2006, 60, codes, ford, forum, hard, ipr, location, powerstroke, run, sale, screen, start, valve, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
