Alternator Ground Wire?
Old 11-20-2011, 08:11 PM
zehcnasca's Avatar
zehcnasca
zehcnasca is offline
On back of my alternator is looks like it has an extra connector with the intials "GRD" by it, does the alternator have a ground wire?
Old 11-20-2011, 08:21 PM
kingford72's Avatar
kingford72
kingford72 is offline
No the alt should get a ground through the engine the 3 wires it should have are
1. the heavy charge wire
2. feild wire, I think its orange and goes to the reg.
3. stator wire, wht and black usually runs the elec choke
Old 11-20-2011, 08:35 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Please review:
Old 11-20-2011, 08:37 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
As KF said, the alternator grounds through the engine block. However, most alternators do have a ground stud which is simply integral to the casing. This can be used to wire a direct ground between the alternator and one of the regulator mounting bolts to give a slightly more accurate sense (otherwise the regulator ground is shifted by any resistance in the ground connection between the inner fender sheetmetal and the engine block).
Ripcity
09-30-2013 03:31 PM
cheddar89
01-25-2012 04:43 PM
fordnc
03-17-2009 06:24 PM
mechanicsburg
16
04-23-2005 07:18 AM
inliner
02-25-2003 02:12 AM
Quick Reply: Alternator Ground Wire?
